Roast leg of lamb and potatoes (Greek style).. the quick and easy way!
Discussion in 'Geek Recipes' started by NIP007, Apr 22, 2009.
  1. NIP007
    NIP007 Member
    Aug 27, 2001
    1,690
    I make this all the time, it's so easy to prepare and always turns out great.
    Ingredients:
    - 2kg leg of lamb on the bone (I like my meat on the bone).
    - About a dozen mid sized potatoes.
    - 2 lemons.
    - Salt, pepper, oregano (or whatever dry herb you like).
    - Garlic.
    - 1 cup olive oil.
    - 1 cup water.
    Method:
    - Pre-heat oven to 180c.
    - Wash the meat and pat dry with paper towels.
    - Peel the potatoes (sometimes I don't) and cut into smaller pieces for faster cooking.
    - Layer the potatoes on the bottom of a roast pan.
    - Place lamb leg on top of the potatoes.
    - Peel garlic, make small incisions in the meat at random intervals and insert the garlic.
    - Pour the juice of one lemon over the meat.
    - Season with salt, pepper and oregano.
    - Pour half the olive oil over the meat.
    - Poor the rest of the oil, water, and the juice of the remaining lemon to the side of the tray so the potatoes are sitting in the liquid.
    - Season the potatoes with salt and pepper.
    Hosted by UGBox Image Store
    Place in the oven and cook for approximately two hours (for medium-medium rare), regularly basting the meat with the juices. If you want you can cover the meat with aluminum foil for the first 1-1.5 hours to keep more of the juices in. After a couple of hours it should look like this :)
    Let the meat rest for about 10-15 minutes before serving. Wopa!
    There's all different variations for cooking time etc... this is the quick way. If you wanted to you could even slow cook it throughout the day at a lower heat.
  2. JebusJones
    JebusJones Member
    Nov 12, 2004
    3,974
    Brunswick, Melbourne
    Pretty much the same way I do my lamb except use variety of vegetables (use that pumpkin!) and tend to rub with mixed herbs instead.
  3. C4ndl3s
    C4ndl3s Member
    Feb 5, 2003
    118
    Pretty much the same as mine, but I like to de-bone the leg of lamb first.
    Also I'll cook everything in it's own tray/dish
    Lamb by itself, raised off baking dish and basted occasionally with drippings.
    Vege's by themselves.
    Potatoes by themselves for super crunchy potatoes.
    After the lamb is done, I take the tray of dripping out onto the stove. Take teh garlic from the lamb and crush it into the drippings then add flour and chicken stock for gravy.
  4. atech
    atech Member
    Jul 15, 2008
    238
    The only similarities i see between yours and the OP's is the leg of lamb - and even that is questionable...
    OP - nice recipe, just what i was after :)
  5. Gorketh
    Gorketh Member
    Aug 19, 2007
    5
    Gosford
    I've cooked this twice this week. The roast potatoes are the best I've had.
  6. Fresh79
    Fresh79 Member
    May 29, 2006
    7,312
    Gonna do this for the first time tonight. When rubbing herbs into the lamb, how much is too much? If I put carrots & pumpkin in with the potatoes do they need the same cooking time as the lamb & potatoes?
    Ta
  7. miicah
    miicah Member
    Jun 3, 2010
    5,687
    Brisbane, QLD
    Roast is possibly the easiest thing to do, the only real work is in the prep.
    Plus you get to learn how to make PROPER delicious gravy.
  8. Shaetano
    Shaetano Member
    Apr 22, 2002
    1,113
    Sutherland
    can't really go wrong with the herbs, you should have a good spread like the OP's first picture
    most recipes will say put the pumpkin and potatoes in at the same time however I've always found the potatoes need an extra 10-15 mins.
    Speaking of lamb, I did a honey & mustard seed marinated lamb roast (with slits of rosemary & garlic) the other week, turned out pretty good.
    Still trying to get used to this oven, has a weird heat zone so potatoes didn't turn out as good as they should have, but can't complain much when you're renting!
    Crappy phone picture (wasn't as red as that)
  9. Fresh79
    Fresh79 Member
    May 29, 2006
    7,312
    Looks good!
    How long to cook a 1.2kg leg of lamb?
    EDIT>>Bout 75 mins?
