Router advice for 1000 mbps internet connection
Discussion in 'Networking, Telephony & Internet' started by ipv6ready, Feb 8, 2019.
  1. ipv6ready
    ipv6ready Member
    Feb 10, 2014
    2,031
    North Sydney
    hi what router would you recommend for 1gbps wan via AAPT fribre1000
    Something tiny and quite, with built in 4 port Ethernet switch and wifi would be perfect.
    Though I can get separate wifi and seperate switch.
    It’s only used by two people and there are no servers in the office etc, so it’s a very simple setup, and not getting full 1gbps is ok.
    Any advice, budget isn’t a big factor but being a small office, quietness is imperative.
    I was told to get Cisco isr4431-1G should I get that?
  2. waltermitty
    waltermitty Member
    Feb 19, 2016
    1,018
    BRISBANE
    edgerouter lite with all the hw offloading
    ipv6ready
    ipv6ready Member
    Feb 10, 2014
    2,031
    North Sydney
    Thanks, looking into it, I saw this Ubiquiti EdgeRouter 6-Port with PoE
  4. davros123
    davros123 Member
    Jun 18, 2008
    2,930
    Yep. ubiquiti. I installed Router X ($85) at a mates place that has 100/100 and it's awesome add a UAP AC lite (~$120) and be happy. Why do you need PoE?
    AC lite comes with a power pack iirc.
    timace likes this.
    ipv6ready
    ipv6ready Member
    Feb 10, 2014
    2,031
    North Sydney
    There are two ip phones, being a small space trying to avoid clutter as much as possible.
  6. fredhoon
    fredhoon Member
    Jun 27, 2003
    2,643
    ipv6ready likes this.
    ipv6ready
    ipv6ready Member
    Feb 10, 2014
    2,031
    North Sydney
    Thanks I’ll have read of microtek.
    Speed isn’t an issue, as there are only two users sharing 1000/1000 mbps link, if each person can get 50mbps it’s plenty.
    in order of importance is Quite And Small, with wifi, and Poe as options. If I can get all four in one package it would be amazing.
  8. timace
    timace Member
    Aug 6, 2003
    1,784
    I don't think that going all-in-one is the best path. Usually because it's trying to do everything, it's underpowered or overpriced.
    My go to would be the Ubiquiti EdgeRouter Lite, a basic 8-port PoE switch (TP-Link SG1008P or the Netgear GS108P) and a Unifi AP-AC-LIte. They're all silent and don't take up a huge amount of space
  9. stiben
    stiben Member
    Aug 5, 2001
    413
    How about a 5 port EdgeRouter PoE + UAP-IW-HD to bring it down to two units?
    ipv6ready
    ipv6ready Member
    Feb 10, 2014
    2,031
    North Sydney
    Yeah will likely use two small units. I was at the office last week, to consider installing a small 8 ru rack and a standard catalyst switch before the fibre install but as soon as I turned the catalyst on, I knew it was to loud.
    The room is barely 3x4 metres.
    Anyone know much about this
    http://www.draytek.com.au/products/broadband-routers/vigor3220-series/vigor3220n/
    Someone posted it but than deleted their post.
  11. Copie
    Copie Member
    Jul 24, 2009
    13,656
    Newcastle
    This is correct, but not the IW-HD, just either a standard pro or a lite.
  12. davros123
    davros123 Member
    Jun 18, 2008
    2,930
    OP. Stop looking. People keep telling you the answer, Edgerouter and UAP...
  13. CiscoDude
    CiscoDude Member
    Feb 2, 2014
    73
    fredhoon likes this.
  14. Hive
    Hive Member
    Jul 8, 2010
    5,387
    Some place far away
    Having used both edgerouters and heaps of mikrotiks, don't bother with the edgerouter. Unless you want to stick the the CLI, They dumb the GUI down so far you may as well be using a Dlink.
    Get a mikrotik.
  15. davros123
    davros123 Member
    Jun 18, 2008
    2,930
    Dumbed down is perfect for me :) I don't want do do CCNA just to setup vlans, NAT and route.
    iptables are meh.
  16. timace
    timace Member
    Aug 6, 2003
    1,784
    ipv6ready
    ipv6ready Member
    Feb 10, 2014
    2,031
    North Sydney
    Thanks for the input, I ended up buying from Mwave.
    Might be an overkill for a temporary office for two people to meet compliance requirement but than so is getting fibre 1000.
    Ubiquiti Networks ES-8-150W 8 Port Managed PoE+ Gigabit Switch with SFP
    SKU#AC02743
    Unit Price: $339.00
    Invoiced Qty: 1
    Subtotal: $339.00
    Ubiquiti Networks UAP-AC-LITE 802.11ac Dual-Radio Access Point
    SKU#AB73108
    Unit Price: $122.99
    Invoiced Qty: 1
    Subtotal: $122.99
    Ubiquiti Networks ER-4 EdgeRouter 4-Port Gigabit Router with SFP
    SKU#AC11135
    Unit Price: $325.00
    Invoiced Qty: 1
    Subtotal: $325.00
    Could have gone with Edgerouter lite for $140 but $180 saving didn’t make sense.
    davros123 likes this.
  18. xc351
    xc351 Member
    Dec 30, 2005
    2,491
    any AC router will do for such a small room. A simple AC1900 will do.
    If each person has 2 phones and 2 computer (laptop and pc) lets say 1 nas (ethernet) and 1 or 2 wifi printers (run these on 2.4ghz)
    I just picked up a dlink AC5300 for $200
    ipv6ready
    ipv6ready Member
    Feb 10, 2014
    2,031
    North Sydney
    I realise it is potentially overkill but we are deviating from Cisco everywhere to low end brand for this one office.
    A catch 22 could have saved extra $500 but if we lose 1 hour of productivity we would be losing $300 (lease and salary)
    Can explain ubiquity cost benefit but would be hard to explain what I was thinking buying $200 netgear.
    If it all works out well I’ll buy another set as spares
  20. timace
    timace Member
    Aug 6, 2003
    1,784
    Good choice - have fun setting it up!
