Running 32bit software under 64bit via VM
Discussion in 'General Software' started by Annihilator69, Aug 14, 2008.
  1. Annihilator69
    Annihilator69 Member
    Feb 17, 2003
    6,043
    Hey guys,
    I was just thinking if I installed XP 64bit on my machine and find a peice of software that does not work in 64bit mode I can still run it in a 32bit VM?
    For example I install 32bit XP in a VM that is running under 64bit Vista. This should work right?
    Same as if I installed win98 in a VM I should technically be able to run old dos games pending if I can find Win98 drivers...
    Especially If I'm running 4GB+ Ram I can just give the VM 2GB ram when I want to play a 32bit game that for some reason won't work under 64bit.
    Has anyone done this before at all?
  2. NSanity
    NSanity Member
    Mar 11, 2002
    17,675
    Yes that will work.
    But remember in VM's you have limited access to direct hardware (so stuff like OpenGL/Direct3D, High-end Gamer Audio etc).
  3. stmok
    stmok Member
    Jul 24, 2001
    8,877
