Ryzen 5000 Series Discussion
Discussion in 'AMD x86 CPUs and chipsets' started by Skramit, Nov 7, 2019.
  1. Aussiejuggalo
    Aussiejuggalo Member
    Sep 14, 2010
    3,288
    Sunshine Coast Queensland
    Intel will retake the gaming lead, no doubt about it but they'll sacrifice everything to do it. Those will probably be hot, power hungry, expensive chips.
    MUTMAN likes this.
  2. raincloudx
    raincloudx Member
    Dec 18, 2007
    1,993
    Victoria
    They've got a while to go:
    kot0005, Gibbon, p3t0r and 1 other person like this.
  3. FuzwaldQO
    FuzwaldQO Member
    Dec 28, 2001
    2,413
    Near Hobart...
    Gibbon and MUTMAN like this.
  4. chook
    chook Member
    Apr 9, 2002
    3,789
    MUTMAN and Gibbon like this.
  5. Zarok77
    Zarok77 Member
    Jan 2, 2020
    1,371
    that it is the 5800x 5ghz boost
    MUTMAN likes this.
  6. ben699
    ben699 Member
    Jun 21, 2002
    393
    my old intel 6600 system currently has 2 sticks of 8g of ddr4 , (2133mhz) wondering how much of a performance hit when stepping up to 5600 ryzen if i dont get new ram, and if i had to get new ram any suggestions?
  7. Zarok77
    Zarok77 Member
    Jan 2, 2020
    1,371
    I would say 50% fps uplift
  8. MUTMAN
    MUTMAN Member
    9,767
    4109
    2133 is a long way from 3600 or even 3200.
    you'd leave a lot of performance on the table by not upgrading your ram
    grab some cheap 3200 crucial ballistic sport lt sticks and be happy
    Sledge and Zarok77 like this.
  9. the Fan-Man
    the Fan-Man Member
    Jun 16, 2009
    1,615
    Kensington, 2033 Sydney
    Lucky you!
    I ordered my 5900X the second it went live on Scorptec. Their ETA was 12/11 but now it's been pushed back
  10. nCrypt
    nCrypt Member
    Feb 12, 2010
    2,527
    watercooling. worth it?
    pain in the ass haha. looks good but
    jjjc_93 likes this.
  11. self_slaughter
    self_slaughter Member
    Dec 12, 2010
    1,744
    I'm on the fence about redoing my loop or just getting a big ass aio and calling it a day.
    Definitely ditching the hard line if I do redo it for the 5950x though. Way too much hassle to swap shit out.
    I'm in deep now, so may as well keep digging and get a 6900xt in a month or so and pull it all apart again. hah
    nCrypt likes this.
  12. mAJORD
    mAJORD Member
    Jun 4, 2002
    12,076
    Griffin , Brisbane
    I too am ditching the hard. I'ts nice, I'll probably still use it for some builds, but not my main. I like the freedom to swap stuff easily. Especially CPU's
    OJR likes this.
  13. Malakai
    Malakai Member
    Aug 21, 2001
    1,060
    Brisbane, Australia
    Well the BIOS versions available for my Asus ROG Strix X570-I Gaming motherboard that support my 5950X are not great. I’m a day one beta tester now it seems. First chiplet regularly boosts over 5GHz low load but the second chiplet doesn’t go over 4.7GHz ever and with an all core benchmark like CB20 none of the cores go over 3.7GHz. Some only go as high as 3.6GHz. Ten minutes of CB20 and max CPU temp is only 67 degrees, something clearly isn’t right. Core voltages during this are under 1.1v. It’s only under a 280mm AIO and ambient room temp is probably mid 20s.
    None of the motherboard temp readings ever change, just sit at a random number give or take few degrees between min and max. CPU temp max hits 90 degrees just web browsing, or so HWiNFO64 says but both chiplets individually never have a max over 76 degrees.
    I’ve tried both AGESA 1.1.0.0 BIOS updates, the first one is patch B, the latest being marked a beta patch C. Same results with both versions.
    I found other people with the same board and CPU having the same problems, namely Optimum Tech on YouTube. I guess I just have to wait for the BIOS to mature.
  14. jjjc_93
    jjjc_93 Member
    Jul 3, 2009
    3,467
    Run ryzen master and see if it's sitting on the PPT or another power limit. Adjust accordingly with Pbo and see what you get while monitoring thermals and frequency.
  15. OJR
    OJR Member
    Jan 19, 2013
    5,664
    It looks like 5050Mhz is the upper ceiling on these CPUs and a decent AiO will get you there. Not sure custom water is worth it.
    nCrypt and MUTMAN like this.
  16. Malakai
    Malakai Member
    Aug 21, 2001
    1,060
    Brisbane, Australia
    Yep they all immediately red line. I'll play with PBO, all core and per CCX today.
  17. Aussiejuggalo
    Sep 14, 2010
    3,288
    God damn so looking at peoples order numbers from PCCG that have been fulfilled, my 5900X order is like 8000 later :wired: :upset:.
    Any one got numbers of PCCG actual 5900X orders? Seems like they had the most of any store... I'll email them next week after they get more stock and see if I can find out where in the queue I am.
  18. nCrypt
    nCrypt Member
    Feb 12, 2010
    2,527
    pre much. but custom water for me always worth it for the gpu!
    will finish mine today and see what thia 5800x can do
  19. OJR
    OJR Member
    Jan 19, 2013
    5,664
    Keen to see the results.
  20. n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,633
    Melb
    Hello fellow memebers...
    Thinking of going a 5900x or 5950x matched with a ROG Strix X570-E.
    Question is, is my ram ok?
    GSkill 3600 16-16-16-36
    2x8GB
    Thanks
    FuzwaldQO likes this.
