Safely switching mains for Arduino
Discussion in 'Electronics & Electrics' started by ShadowBurger, Jul 29, 2020.
  1. ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    2,156
    Hey all
    Per title. Yep I'm aware I can get "relay modules" to suit my arduino, however these are DIY and obviously not legal.
    I'm wondering if anyone knows of any off the shelf products which are essentially the same thing but packaged as a sealed unit with a low voltage input designed for hobbyists to safely switch mains loads on and off? Bonus points for built-in anti-bounce to prevent fast switching.
    Cheers,
    Shads
  2. RobRoySyd
    RobRoySyd Member
    Jan 24, 2008
    8,228
    Look for a "smart WiFi plug". I have one that's marketed under the "Brilliant" brand, I think it came from Bunnings, The only problem is getting an Arduino to talk to it.
    As for anything DIY so long as you're not wiring it into fixed wiring there's nothing illegal about making a mains powered appliance for your own use, at least not in NSW.
    On the other hand even an approved device that is designed to be wired into fixed wiring has to be installed by a licensed electrician.
    ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    2,156
    Had a quick look, thanks, but it defeats the point if I have to hack it to get it to do what I want
    starting with a search for "Smart WiFi plug with API" I did manage to find some solutions but I really don't want to have to depend on WiFi for this application. I'll keep looking
  4. oculi
    oculi Member
    Aug 18, 2004
    11,710
    servo driving a cam acting on a garden variety mechanical switch? I don't have a need for switching 240 Volts but figured I would use some kind of relay if I did (I worked out a cheap way to get an Arduino to switch relays a while back) I think I'll do it mechanically now as it's funnier.
  5. mtma
    mtma Member
    Aug 12, 2009
    5,612
    ShadowBurger likes this.
  6. kjparker
    kjparker Member
    1,450
    Those plugs use an esp8266 based controller in them, which can be reflashed with alternative firmware, one of the most popular being tasmota. This gives you an http interface and an mqtt interface. I have a few of these plugs, and I have had no issues to speak of with them so far.
  7. mAJORD
    mAJORD Member
    Jun 4, 2002
    11,442
    Griffin , Brisbane
    So you want it to have an au mains socket on it off the shelf yeah?
    ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    2,156
    that sounds very doable, have you got links to the exact ones you got?
  9. kjparker
    kjparker Member
    1,450
    I have currently a mix of the Bauhn ones from Aldi, and the Brilliant ones from Bunnings. I bleieve the Arlec Gridsmart ones are also compatible, and can be flashed OTA using "tuya Convert" (google it). https://templates.blakadder.com/au.html will give you a template for the device to help with the config
  10. 7nothing
    7nothing Member
    Feb 15, 2002
    1,531
    I was trying to do it with 433mhz transmitter and existing remote switched powerpoint.
    After a short time trying to capture signal from the powerpoint remote, I wasn't getting any reading on the arduino. Bought a moderately cheap USB scope to see if there was output on the receiver connected to the arduino, haven't plugged it in yet.
    That was like 3 months ago and haven't progressed :)
  11. Higgsy333
    Higgsy333 Member
    Jan 19, 2002
    34
    ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    2,156
    That's an awesome place to start, cheers.
    Looking into how an APC switched PDU is built inside, it only has 16A ~ 250v relays. I was sort of expecting something much more heavy duty especially with the inrush load of the capacitors in a server power supply. That does make me somewhat more comfortable with using a (quality) off the shelf relay for the kind of switching I want to do, even if I'd rather not build something myself
    I've had experience with my 400W LED grow light welding the relay contacts closed on a cheap arduino module, hence wanting to avoid them in future. Maybe all I need to do is swap out the relay for one I can trust
  13. rockofclay
    rockofclay Member
    Nov 10, 2002
    1,644
    Melbourne, 3056
    How often were you switching the load? It may be worthwile going the SSR route. They can do a lot more cylces than a mechanical relay.
    ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    2,156
    twice daily
  15. rockofclay
    rockofclay Member
    Nov 10, 2002
    1,644
    Melbourne, 3056
    Meh, shouldn't be too bad. I think 50000 cycles is pretty normal for a relay IIRC.
  16. mtma
    mtma Member
    Aug 12, 2009
    5,612
    Well if it's directly on an inductive load, the conditions may be a lot more severe. But SSR's of late seem to have been put on some undeserved pedestal, you need to make sure you have the right SSR and setup there for inductive situations too.
  17. callan
    callan Member
    Aug 16, 2001
    4,950
    melbourne
    I have done precisely this with a Commodore 64 and a remote controlled mains switch, and a Vicā€Rel relay cartridge, and 10 lines of BASIC code. I just soldered wires directly to the controller button pads. Worked a treat, perfectly safe and perfectly legal.
