Samsung Galaxy Note 4 SD805 2.7GHz\1440p - Galaxy Note Edge
Discussion in 'Google Android (OS & Devices)' started by 2SHY, Sep 4, 2014.
  1. CHiMPY
    CHiMPY Member
    Mar 10, 2002
    311
    In a house
    Yeah, I have tried a number of different case off/reboot/case on etc combinations.
    It is actually at a point where I have to keep a small piece of paper in the case blocking the contacts because the phone will freak out and no matter what I do it thinks the case is always closed and the only thing that works is the edge screen.
    Factory reset the phone, problem persists.
    Have not thought about wiping cache, is that even an option on a non rooted phone?
    I would love to go back, but without rooting the phone is that even a possibility? Can't root/run custom firmware since the phone is used for work.
  2. Cpt.J.Sparrow
    Cpt.J.Sparrow Member
    Sep 14, 2010
    1,215
    No need to root, but being able to use a search engine helps. ;)
    Here:
    Wiping cache partition
    Going back to KitKat
    The only tricky and time-consuming part will be finding and downloading the stock KitKat firmware for your handset.
  3. hippyhippy
    hippyhippy Member
    Apr 1, 2004
    8,808
    Just installed update. Feels abit snappier. Hopefully this might fix my battery issues.
  4. CrazyNuts
    CrazyNuts Member
    Aug 6, 2002
    1,353
    Perth, WA
    Anyone using the Telstra Note 4 and done the update yesterday? What are your thoughts?
    I'm getting a bit annoyed at the random resets and regular facebook crashes etc.
    Not sure if it's my phone, if it is I have no way of proving it for warranty purposes anyway.
  5. Julz
    Julz Member
    Jul 4, 2001
    2,709
    Melbourne, Victoria
    I haven't had any issues so far - my battery is already borked and I've also uninstalled Facebook due to the battery drain.
    Has anyone had their Samsung fast charge wall charger die? I just went to use mine after not using it for probably 3 weeks and it doesn't work anymore! :( It was plugged in so I'm wondering if a power surge or something killed it?
  6. Cpt.J.Sparrow
    Sep 14, 2010
    1,215
    Missus and I haven't experienced any issue post-5.1.1 with our Note 4s. Having said that, we no longer use Android Facebook app; instead we use the mobile site with Chrome (with notification on, of course). Facebook app has to be the worst built-in app for Note 4.
    When was the last time you did factory reset? There were some big updates prior to the last two security updates. If you haven't done after 5.1.1, do a backup and try a factory reset. I went from 4.4.4 to 5.1.1, and the factory reset made the phone even more responsive.
  7. Cpt.J.Sparrow
    Sep 14, 2010
    1,215
    Using the OEM or decent cable? If using a generic el cheapo rubbish, it might not charge superfast because it could struggle with modest 2A current.
    Mine failed after only 4 months of daily use even though it was plugged into an expensive double conversion sine wave UPS. When they fail, they fail. OEM chargers are generally better than Belkin and generic shit, but they are still cheaply made.
  8. Julz
    Julz Member
    Jul 4, 2001
    2,709
    Melbourne, Victoria
    Hrmm bummer - was using the original Samsung USB cable with it. I guess the charger is going in the bin.
  9. aussie-revhead
    aussie-revhead Member
    Feb 21, 2005
    19,850
    St Clair 2759
    Guys, Im looking for an upgrade from my Note 2 but I have seen a few Note 4's with images burnt into the screen, is that a common problem with this screen?
    Thanks
  10. C4Z4M
    C4Z4M Member
    Aug 17, 2001
    191
    Occupation:
    I would say no more than any other oled screen. Much better than my sgs4
    If you have any static hud/gui items on the screen for hours a day you will eventually notice then some times when on a white or light coloured screen with no pattern.
    I have been playing ingress a lot, maybe over 1000hrs over the last 12months mostly at Max brightness and I am only just now noticing some HUD items. Most of the time you can't see it.
  11. Julz
    Julz Member
    Jul 4, 2001
    2,709
    Melbourne, Victoria
    I havent noticed anything at all. How would I check?
  12. aussie-revhead
    Feb 21, 2005
    19,850
    St Clair 2759
    On a bright plain screen look for faint images still visible.
    :thumbup:
  13. Cpt.J.Sparrow
    Sep 14, 2010
    1,215
    Phone>enter *#7353#>TSP Dot Mode
    Phone>enter *#0*#>Blue
    and have a good look.
    Had Marshmallow on my Korean Exynos Note 4 for over two weeks, and much prefer 5.1.1 with Stagefright/misc. fixes updates. I have turned off Auto update on my Aussie Snapdragon Note 4. Another meh update from Samsung.
  14. Cpt.J.Sparrow
    Sep 14, 2010
    1,215
    It appears to me Marshmallow update for 810G is pretty buggy. If you haven't rooted your Aussie Note 4, stick with 4.4.4 or 5.1.1 with Stagefright fixes.
    I am beginning to think we should just avoid the final OS update for Note-series. Jelly Bean for the original Note, KitKat for Note 2, and Lollipop 5.0 for Note 3 were all very disappointing.
  15. aL4n
    aL4n Member
    Aug 18, 2003
    714
    Gave MM a try, rolled back to Kitkat in the end
  16. dukkie
    dukkie Member
    Oct 9, 2002
    1,750
    Hey guys,
    My battery on my Note 4 is starting to crap itself, where is the best place to get genuine batteries? Unfortunately Samsung don't have any stock online.
  17. aL4n
    aL4n Member
    Aug 18, 2003
    714
    Same issue with my battery, bought one off ebay but got a refund after couple days. The phone was randomly shutting down and would reboot. Let us know where if you find a "genuine" one.
  18. Julz
    Julz Member
    Jul 4, 2001
    2,709
    Melbourne, Victoria
    I bought a supposedly 100% genuine one from ebay and turned out to be fake. I left a negative feedback and demanded a refund. The f#($er threatened me personally telling me he knew where I lived. Reported to eBay and they did nothing.
  19. Cpt.J.Sparrow
    Sep 14, 2010
    1,215
    If you are having a lot of difficulty buying genuine batteries, let me know. It's $28 each in South Korea.
    Best to turn off fast charging unless you really need it because of time constraint. My original battery caused power downs at around 20%. After 20 odd slow charging cycles, it stopped doing that and doesn't turn off even at 5%. My two newer batteries that were never fast-charged saw only a minimal drop (guesstimate of 5%) in charge over 120 cycles (roughly a year). My guess is that fast charging generates a lot of heat, which can't be too good for Li batteries, and accelerates battery degradation.
  20. aL4n
    aL4n Member
    Aug 18, 2003
    714
    I'm experiencing the issue of ~20% power down, so you saying I can fix this issue if I turn off fast charging?
