Samsung Galaxy S7/S7 Edge - SD 820/4GB Ram/Micro SD/Water Resistant
Discussion in 'Google Android (OS & Devices)' started by walker_2003, Feb 22, 2016.
  1. therazza
    therazza Member
    Aug 19, 2004
    1,415
    A few big features:
    the do not disturb will allow a certain caller to still come thru. IE- wife (we're shift workers)
    built in blue light filter and torch, removed x2 3rd party app's
    split screen
    also reckon I am getting ever better battery life now easily steching a further 10% a day
  2. xplod140
    xplod140 Member
    Jun 1, 2002
    4,654
    Melbun
    I just got the update today. Fingerprint sensor is crazy fast compared to before, or maybe it's just the load time to the home screen. Regardless, it's noticeable.
    Not really a fan of the stock launcher and Nova doesn't work as well as before (icons aren't compatible) so I might have to find another one.
    I think the pulldown menu was better on M but I guess I can get used to it now that I figured how to make it 'not fucking white'.
  3. birdie
    birdie Member
    Jun 18, 2002
    2,877
    Bundaberg, Queensland
    I use the Google Launcher... much better than the stock launcher...
  4. chargin
    chargin Member
    Jul 16, 2001
    1,390
    With the S8 coming soon what might the S7 drop to price wise in the next few weeks?
    Hard to say I know, but if it will drop more than say $100 I can wait a few weeks, otherwise I might get one now, Kogan have them for about $665 which seems an ok price.
  5. xplod140
    xplod140 Member
    Jun 1, 2002
    4,654
    Melbun
    Yeah I tried a bunch of others and they all sucked so went back to Nova. Still more fluid and feels faster than TW.
  6. connico
    connico Member
    Jan 30, 2004
    4,820
    Does anyone know how to remove the white surrounds on the icons???
  7. supasaiyan
    supasaiyan Member
    Nov 17, 2006
    5,272
    3000
    Display, Icon Frames
  8. connico
    connico Member
    Jan 30, 2004
    4,820
    You are a gentleman and a scholar
  9. Asteroid
    Asteroid Member
    Jan 6, 2005
    2,447
    Lapping Freo
    Mine updated a few days back. Has anyone found the battery life has reduced a bit? I've checked all the usual things.
  10. Johnbu
    Johnbu Member
    Jul 14, 2005
    3,205
    SE Melbourne
    Can't say I noticed it.
    But I'm not receiving phone calls and getting notified of my voicemail up to half an hour after the call.
    Not sure if it's the network or phone but it started happening around the same time as the update.
  11. Asteroid
    Asteroid Member
    Jan 6, 2005
    2,447
    Lapping Freo
    It seems to last like 5.5 hours of screen time. Before the battery lasted so long I never gave it a second thought. I do have it set to wqhd res - but that's what it was before. Seems a bit shit to have to scale it down just to last.
  12. Asteroid
    Asteroid Member
    Jan 6, 2005
    2,447
    Lapping Freo
  13. xplod140
    xplod140 Member
    Jun 1, 2002
    4,654
    Melbun
    Mine is the same or better for battery life. Day and a half between charges with quite a bit of twitter use at full res.
  14. Stooge007
    Stooge007 Member
    Aug 22, 2006
    11,477
    The Shire, Sydney
    having issues (again) with my S7
    the home and recent apps buttons have randomly decided to stop working
    this happened before, but i can't remember how i fixed it
    the home/fingerprint button works to unlock the phone, but once unlocked it stops working
    also used to have double tap home goes to camera, that doesn't work either
    tried booting in to safe mode and wiping cache partition, still doesn't work
    haven't installed any new apps, not sure if it updated any overnight
    any ideas?
  15. kogi
    kogi Member
    Jan 23, 2003
    4,912
    2031
    Send it back to samsung for warranty. I think you have a lemon
  16. Stooge007
    Stooge007 Member
    Aug 22, 2006
    11,477
    The Shire, Sydney
    Don't think so, I've fixed it before, just can't remember how I fixed it!
    EDIT - updated to Nougat and that seems to have fixed it
  17. breno
    breno Member
    May 3, 2011
    1,793
    Just got an S7 yesterday. Notification to upgrade to Nougat was there as soon as I turned the phone on. I see there's an option for WQHD res, I'm assuming that would take a bigger chunk on battery life. Anyone using phone at that res? If so, what results?
  18. Stooge007
    Stooge007 Member
    Aug 22, 2006
    11,477
    The Shire, Sydney
    think it says around 10% reduction in battery life
    haven't tried it myself
  19. breno
    breno Member
    May 3, 2011
    1,793
    Cool, not too bad, wonder if I'd see a difference, only one way to find out.
    Also, i wanna root this phone. Haven't rooted a phone in a while, if I were to do so, I say goodbye to carrier upgrades right?
  20. idiot_child
    idiot_child Member
    Jan 11, 2003
    1,349
    I'm waiting for my phone so can't say for sure, but been doing some reading. I think you also say goodbye to S Health and Knox (although I don't know what that actually means)
