saw blades for acrylic/perspex
Discussion in 'Modding' started by deluxe, Jul 3, 2014.
  1. deluxe
    deluxe Member
    Dec 9, 2003
    621
    Hi All
    I've recently acquired a table saw and am looking at getting a blade for cutting acrylic. I've read that high-tooth count blades with zero degree rake are the go, or Triple Chip Grind blades with zero rake.
    Have a couple of questions:
    Does anyone know where to easily get an inexpensive blade for this?
    Can I use negative raked blades?
    Cheers :thumbup:
    edit: 235mm saw with 25mm arbor...
  2. Ch4iS
    Ch4iS Member
    Jul 2, 2008
    828
    swsyd
    deluxe
    deluxe Member
    Dec 9, 2003
    621
    Champion! thanks mate, I didn't think to try masters..
    deluxe
    deluxe Member
    Dec 9, 2003
    621
    ooooooh you have cnc routers....:weirdo:
  5. Meth
    Meth Member
    Jul 2, 2001
    62
    Melbourne - Grantville
    More teeth per better will give a finer cut with less variation/grooves - more important is speed of cut (If you think about it, this is all more TPI does anyway, notwithstanding bluntenning of the cutting surfaces)
    Lubrication will make a massive difference also...... before you cut, push a bar of soap against the blade, I've found Salvol works well on our CNC Spiral cutters when cutting Perspex - lasts a long time surprisingly too on each cut
  6. clonex
    clonex Member
    Jun 30, 2001
    25,997
    north pole
    From the states thru ebay, 2-3 blades for the same price as 1 one here.
    Tradetools blades arent too bad depending on the blade $$$ wise.
    Most hdd sell wax bars to rub on blades when cutting non timber materials
  7. JonnoHR31
    JonnoHR31 Member
    Jan 4, 2012
    195
    Silicone spray is another thing you can use on the blade, works well :thumbup:
  8. mr626
    mr626 Member
    Jul 17, 2011
    2,762
    I've cut a bit of perspex recently. Had never done so before, so a bit of experimentation was in order :Paranoid:
    -Angle grinder with metal cutting disk. Would you believe it, this was horrible. Melted more than cut. Do not do this
    -Circular saw: much better- this is what I'd use again if I didn't have the proper tools
    -Jigsaw: useless (mind you, it was a cheap and nasty jigsaw and it was fairly thick perspex).
    Great points from Meth about lubrication, wish I'd thought of that at the time.
  9. the3coopers
    the3coopers Member
    Jan 7, 2012
    1,685
    Sydney 2151
    Best (cheapo, non-specialised) thing to cut perspex is a standard hacksaw.
  10. mr626
    mr626 Member
    Jul 17, 2011
    2,762
    That may be true, but for what I was doing it would have taken ages:
    -25mm thick perspex
    -Cutting a large (2m x 1.5m) chunk out of a much larger sheet
  11. 2xCPU
    2xCPU Member
    Jan 21, 2005
    3,327
    Saigon
    You'd be surprised how good a finish you can get with a friction disc (angle grinder disc) with a little lube/ coolant. I've used water, oil, WD40 - all work well.
    2.
  12. clonex
    clonex Member
    Jun 30, 2001
    25,997
    north pole
    Depends on the cutting disc, inox 1.0mm ultra cut disc make easy work of it.
    Like cutting anything let the disc do the work not your arm.
    If using a jigsaw just make sure your blade is very very fine.
    Lots of cutting ill just use the makita cold cut saw with a fine +60-80tooth metal blade.
    Better off getting those multi material/ferrous metal blades from the states.
    2 for the price of 1 here
