Seagate 8TB drives
Discussion in 'Storage & Backup' started by AEKaBeer, Dec 31, 2014.
  1. rainwulf
    rainwulf Member
    Jan 20, 2002
    4,275
    bris.qld.aus
    This is correct. They are like super slow SSDs in this respect, as they do a read, modify, write on existing data.
    It also means that they treat the SMR section as a "data pool" and its not actually physically mapped as a normal drive. So when you write a new file, it just finds the next free section in the pool and writes it. When you modify a file, it reads from the SMR section, modifies it, and then writes it back to a clear section of the SMR area.
    Once the drive is filled with data though, where a "TRIM" would be useful, they go into read modify write on the same tracks, and that's where they can get very slow, as they have to read the entire track, modify it, and then write the entire track back again, even for a 1 byte change.
  2. aza2001
    aza2001 Member
    Sep 14, 2002
    2,016
    Northmead
    so is anyone running this in an mdadm array?
  3. aokman
    aokman Member
    Jul 12, 2001
    14,177
    Mexico
    Don't be too hasty lol the Hitachi's are brilliant, though I will say my 5TB Toshiba's have been flawless as well. Ill never touch another Seagate again though don't care if they give them away.
  4. claf-43
    claf-43 Member
    Aug 5, 2003
    7,596
    Thinking of turning my pc into my NAS as well. Will just run it in sleep mode.
    Thoughts in storing all my media on one of these? Won't be raid, obviously not a system drive either.
    I was looking at just getting a 8tb red internal with one of these as a backup externally. Saving around $200 seems ok though.... Not sure it's worth the difference in price to be honest.
  5. wintermute000
    wintermute000 Member
    Jan 23, 2011
    2,562
    For home media I reckon a pair of the cheap archive ones would suffice, esp if you can get them from different batches.
  6. claf-43
    claf-43 Member
    Aug 5, 2003
    7,596
    Just thinking as an interim it should be ok. I am keen on a 10-12tb single drive when they do rock up....
  7. aza2001
    aza2001 Member
    Sep 14, 2002
    2,016
    Northmead
    so no one is running these in mdadm?
  8. g00nster
    g00nster Member
    Sep 10, 2004
    352
    ain't no one got time for mdadm rebuilds!
  9. aza2001
    aza2001 Member
    Sep 14, 2002
    2,016
    Northmead
    I see most use zfs, doesn't zfs take time to rebuild?
  10. ar3nbe
    ar3nbe Member
    Mar 3, 2007
    33
    Would these drives be suitable to put into my NAS for video* files that I will stream to other devices in the house?
    The drive will not be put in a RAID. I have other drives for that. So basically, minimal writes and semi occasional reads while watching videos.
    From the comments it seems that this is almost was this drive was designed to do?
    *Mostly 1080p GoPro footage that I have backed up elsewhere.
  11. f0d
    f0d Member
    Mar 28, 2011
    99
    Frankston North,Vic
    ok i just bought one of these (8TB archive) but im a little worried about reliability after reading about a bunch of horror stories on amazon and newegg
    how has everyone elses been? anyone have one that died?
    things like speed dont bother me - i knew it was going to be slow but i dont really care as its just to store videos for my htpc, its going to be written to once and thats it
    i just dont want to fill it up then it die on me :upset:
  12. claf-43
    claf-43 Member
    Aug 5, 2003
    7,596
    Got 3 myself now, all will be backup only, eventually....
    Was painful for a daily drive but luckily no issues yet.
  13. jezza323
    jezza323 Member
    Apr 7, 2005
    1,375
    Ive had one as my primary media drive running plex in a microserver for >6 months
    So far so good
    I make sure everything is backed up in anycase
  14. g00nster
    g00nster Member
    Sep 10, 2004
    352
    I've had 16 running in a zpool (2x vdevs of 8 drives in raidz2) for almost a year without hiccup.
    I've never had an issue copying data (120MB/s) via SMB and read speeds are great too (~140MB/s per disk, ~~2GB/s for zpool on scrub)
    http://imgur.com/zozE4sh
    http://imgur.com/MOLS9f4
  15. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,615
    Perth , St James
    I'm still rocking 6 of these in Raid 5, I had a few issues a couple of months back but that turned out to be a funky cable .
    Strange thing is i rebuild the array several times and the times was not too bad at all ,36 hours compared to say 10 for my 4Tb drive arrays which considering they are twice the size is not bad (3.6h/T vs 2.5h/T).
    Maybe my controller was just verifying the data rather than rewriting it thought it did specifically say rebuilding rather than verifying .
