Sega Universal Upright conversion
Discussion in 'Retro & Arcade' started by mR_CaESaR, Feb 16, 2019.
  1. Vanne
    Vanne Member
    Apr 20, 2003
    724
    Wow !! This is amazing, thanks for documenting the whole thing. :)
    AMAZING stuff.
    mR_CaESaR likes this.
  2. MUTMAN
    MUTMAN Member
    6,282
    4109
    great work there mR_CaESaR
    I dont know how much work the pi has to do, but that case (i have two) has zero airflow.
    grab a $2 heatsink for the pi and pop off one or both of the side covers (or the top if not concerned about dust settling)
    mR_CaESaR
    mR_CaESaR Member
    Mar 10, 2002
    2,860
    Plumpton NSW 2761
    The pi doesn't do much.. it's just used to load the game onto the DIMM.
    That said, I'll remove the side covers
    MUTMAN likes this.
  4. elvis
    elvis Old school old fool
    36,686
    Bugger all. Pushes a file via a network protocol, goes to sleep.
    Could be done on much lower end hardware, but ironically enough a Pi is a simpler/cheaper way to do it due to mass production.
    mR_CaESaR and MUTMAN like this.
    mR_CaESaR
    mR_CaESaR Member
    Mar 10, 2002
    2,860
    Plumpton NSW 2761
    I could've used an original pi or even the 2, but I wanted the in built wifi just because I didn't want to be scrolling through on an adafruit 16x2 LCD :) (just doesn't make sense to buy a pi1 then adafruit lcd)
  6. Vanne
    Vanne Member
    Apr 20, 2003
    724
    Awesome, one day you guys should do a proper complete write up on the Naomi, I love how close it is to the DC and the quality of the games. Very, very awesome!!!
  7. MUTMAN
    MUTMAN Member
    6,282
    4109
    in that case you should be able to get away with it closed up on all sides :thumbup:
    mR_CaESaR
    mR_CaESaR Member
    Mar 10, 2002
    2,860
    Plumpton NSW 2761
    I don't play games! I just tinker and make stuff in a workable state then I move on :D :D
    That said, this project has been the longest and has had the most work involved. I was luck in that the whole internal wiring was still intact and operational (except the monitor)
  9. elvis
    36,686
    This made me laugh, then cry, because I do it too.
    FIREWIRE1394, Vanne and mR_CaESaR like this.
    mR_CaESaR
    mR_CaESaR Member
    Mar 10, 2002
    2,860
    Plumpton NSW 2761
    Story of my life.. My Mrs always says "are you actually going to play?" haha
  11. Vanne
    Vanne Member
    Apr 20, 2003
    724
    Lol I guess we all do this to a certain extent. Lol. either way, I really like the progress and the write up you compiled together.
    FIREWIRE1394 and mR_CaESaR like this.
  12. FIREWIRE1394
    FIREWIRE1394 Member
    Sep 20, 2012
    849
    Yeah, massive Kudos for this project.
    Can’t wait to see it finished and the final picture next to the first, and of course the next project.
    Have a virtual hi five and beer!!
    MUTMAN likes this.
    mR_CaESaR
    mR_CaESaR Member
    Mar 10, 2002
    2,860
    Plumpton NSW 2761
    And... The restoration has taken another dive! :(
    As I was trying to sort out the piforce, I noticed the image go funny - it became large and then the image pinch and became like an hour glass (not that bad, but concaved)
    Shortly after when the Naomi rebooted, the signal wasn't present (but the sound was) and it sound like the monitor was trying to turn on.
    And then the smell.... There was an electrical smell that was very present in the air..
    Back to square 1 looking for a 31khz monitor. I'll disassemble the chassis and try and find some sort of identifier to see if I can get a replacement as I know Jomac doesn't really fix 31khz chassis.
    Hopefully I can also find the "burnt" section and see what the damage is.
    I'd love to know how this happened, the monitor and chassis was secured, no wires touched (that I could tell anyway) and the input voltage was coming out of the transformer - if it was going to fail due to incorrect input voltage, I would've thought this would have occurred earlier.
  14. qwertylesh
    qwertylesh Member
    Aug 21, 2007
    8,554
    Damn dude.
    I hope u find the root cause
    mR_CaESaR
    mR_CaESaR Member
    Mar 10, 2002
    2,860
    Plumpton NSW 2761
    Doubt I ever will... :(
    mR_CaESaR
    mR_CaESaR Member
    Mar 10, 2002
    2,860
    Plumpton NSW 2761
    In light of issue that occurred, on a good note, I fixed the my piforce issue I was having - no idea how, but loading bins is now possible on a web browser!
    MUTMAN likes this.
    mR_CaESaR
    mR_CaESaR Member
    Mar 10, 2002
    2,860
    Plumpton NSW 2761
    Chassis pics
    Some impedance readings (hopefully this is correct)
    MUTMAN likes this.
  18. ShaggyMoose
    ShaggyMoose Member
    Jul 1, 2002
    368
    Isn't it likely to be a single component?
  19. qwertylesh
    qwertylesh Member
    Aug 21, 2007
    8,554
    Also how old was the tube, are you sure the smell is definite component failure? Isnt it possible the issue and smell are unrelated, when i got my arcade unit it was unused for a long time and upon powering it up a lot of dust burnt off the back of the electron gun, it smoked and smelt but the hardware was fine
  20. breech
    breech Member
    Mar 6, 2002
    1,853
    GalaxyWorld
    An hourglass / vertical line fault is called horizontal collapse. If you're ok with a soldering iron try refresh any crusty solder joints. Start with the 4 in the middle, reflow the circle of flyback pins and concentrate around the flyback where the transistors are mounted to the heatsink. Look for burnt components around there. Check on aussiearcade etc for similar faults.
    flain likes this.
