Selecting a Cube Case for a HUMONGOUS CPU Cooler!
Discussion in 'Modding' started by Digidave, Mar 1, 2019.
  1. Digidave
    Digidave Member
    Jan 23, 2018
    20
    Functionality - sorry if this is in the wrong section.
    _____________________________________________
    Hi there,
    I'd like to go a CUBE Case not because I am doing liquid cooling, but because I am using a the Very ... VERY... large CPU air cooler otherwise known as the Noctua MH-D15 (S series) This things is HUGE!!! The main reason I am getting it is because of how silent it runs and despite not overclocking, I will be stressing my CPU up to 95% for hours on end every day of every week.
    I am well aware of that this Air Cooler being as large as it is, may present fitting issues with respect to the position of some motherboard PCI-E X16 slots; thus interfering with the Graphics Card. I contacted the seller, of the Motherboard I am thinking of purchasing to check their thoughts. They assure me the cooler will fit. However I beleive the top PCIeX4 slot will be inaccessible once the cooler is installed. That's no big deal for me.
    All parts going into the case are compatible for both fit and to ensure no conflicts.
    MY PARTS LIST:
    CPU - Intel Core - ................... i7 8700K Six Core LGA 1151 3.7 GHz
    GRAPHICS - ............................... Galax GeForce GTX 1080 EX OC 8GB
    CPU COOLER - .......................... Noctua NH-D15S Multi Socket CPU Cooler
    MOTHERBOARD - ................... Gigabyte Z390 Aorus Pro WIFI ATX LGA1151
    RAM - .......................................... - G.Skill 32GB (4x 8GB) F4-3000C15Q-32GTZR DDR4 3000Mhz Trident Z RGB
    HDD’S - ...................................... TWO Samsung 970 EVO Series 1TB M.2 2280 NVMe SSD
    POWER SUPPLY ...................... Corsair HX850i 850W 80PLUS Platinum Full Modular
    COULD ANYONE RECOMMEND A CUBE CASE best suited for an ATX Motherbaord?
    I don't want one overly large, yet I do want one that will allow more than enough space for the HUGE Noctua Cooler.
    There seems to either be a lot of micro cubes or server sized cubes. Is there anything in between that would suit my needs?
    Another reason I like the cube case is because some allow you to lay the case flat so that the motherboard is flat. I feel this would put less stress on the motherboard at this CPU Cooler is not only humongous but to some degree also heavy.
    Could anyone help me out with a couple of options / recommendations.
    I do worry about some of the cube cases letting a lot of dust in ... thoughts?
    Is there a CUBE case in between micro and Fridge size?
  2. rvrftw
    rvrftw Member
    Jan 26, 2015
    161
    Hobart
    The only cube case I can think of is the Corsair Carbide Air 540...
    It will definately fit a D15.
    Do you move the case around alot?
    As you will find a side mounted D15 will be fine, unless you lug the case around a lot, then you might need to be careful.
    DSTM (Dougie) likes this.
  3. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,074
    Perth , East Vic Park
    I would get a Cube case because you like them not to fit a specific cooler. The D15 will fit into a lot of larger cases and even then the different between a D15 and one of the slightly smaller coolers is only 1-3c normally which I doubt will make a huge different in noise. Also I have not seen any Mobos break due to large coolers so I don't think being vertical is a huge issue unless you transport it around a lot on bumpy roads in a vertical orientation.
  4. museumman
    museumman Member
    Jan 7, 2002
    207
    TT LEVEL 20 iirc can be horizontally oriented from memory.
  5. self_slaughter
    self_slaughter Member
    Dec 12, 2010
    1,441
    4165
    I've had a board fail with a fairly lightweight (compared to a d15) coolermaster ~212 cooler.
    Started getting sketchy about posting, was testing ram etc but found putting pressure on the cpu cooler (ie pushing it towards the motherboard) would bring it back to life. lol
    Took quite a few years, but it did take its toll eventually. It didn't have a backplate or any kind of support though.
  6. Ratzz
    Ratzz Member
    Mar 13, 2013
    8,052
    Cheltenham East 3192
    The only commonly available cube case I can think of is the Air 540 as mentioned. I'd like to suggest however that you consider the bequiet!! Dark Rock Pro 4 as a candidate for a cooler. Its every bit as effective (and large :lol:) as a D14S, doesn't cost you a PCIE slot, and is even quieter. It also comes with clips to add a 3rd fan, which could potentially even make it a more effective cooler than the D14S.
  7. hairy
    hairy Member
    Dec 11, 2010
    585
    tower 900.
    its huge but will fit pretty much anything on the market
