Setting Wifi with different IP
Discussion in 'Networking, Telephony & Internet' started by bumography, Nov 11, 2019.
  1. bumography
    bumography Member
    Mar 8, 2006
    1,530
    Adel
    Hi,
    I have a static IP range at work with 126 IPS (255.255.255.128 subnet).
    The IPs i can use are eg 203.7.70.2-126
    I recently got an Asus RT87u, and would like to use an internal range for the wifi (192.168.1.x)
    I've tried plugging a cable into the WAN port and setting the WAN with an unused IP 203.7.70.100. NAT is on, Upnp is on, is there anything else i'm missing as i can't seem to access the internet when my phone is connected (unless i statically change it to 203.7.70.xx)
  2. Zee
    Zee Member
    Oct 27, 2002
    11,156
    SYD/MNL/SIN/SFO
    Sssoo... Unless your phone IP address is 203.7.70.xxx, you get no net? Something wrong with phone network settings. You shouldn't have to mess with your IP range to get net. I'd be resetting network settings on the phone to start with.
    Z...
    bumography
    bumography Member
    Mar 8, 2006
    1,530
    Adel
    I just added a rout and it's all fixed.
