Shine a laser perpindicular to ground
Discussion in 'Science' started by Pianist, Jul 19, 2008.
  1. Pianist
    Pianist Member
    Oct 7, 2005
    727
    Hey guys,
    I was thinking that lets say i shone a laser perpendicular to the earths surface at that point, would the beam just carry on forward into space or would it curve around the earth and hit me in the back?
    The diagram explains what im trying to say
    Thanks
  2. scottath
    scottath Member
    Aug 16, 2007
    2,575
    My Yr 11 knowledge of last terms phyics is helpful.....WOW
    In Theory it would be the second option of continuing of in a straight line - but particles in the atmosphere and the atmosphere itself would refract the light so it would curve a little before going straight again - but will still leave the atmosphere in a straight line
    Make sense?
  3. -KoMoD0-
    -KoMoD0- Member
    Dec 26, 2005
    9,033
    Western Sydney
    It will go straight :thumbup:
  4. pippin88
    pippin88 Member
    Jul 26, 2001
    7,406
    Newcastle
    Do you perhaps mean parallel to the earth's surface?
  5. SLATYE
    SLATYE SLATYE, not SLAYTE
    Nov 11, 2002
    26,849
    As above, it'll go roughly straight. The atmosphere and Earth's gravity will cause a tiny bit of curving, but it certainly won't curve around to hit you again.
    Pianist
    Pianist Member
    Oct 7, 2005
    727
    yeah, to the flat surface that im standing
    ok so it bends a little bit, if the earth was bigger say as big as the sun, would it curve along the surface or still continue straight?
  7. scottath
    scottath Member
    Aug 16, 2007
    2,575
    Same as before - small curve.
    If you were to do it on the sun though [assuming you survived] i would say it would go straight - as the sun has no atmosphere.
  8. -KoMoD0-
    -KoMoD0- Member
    Dec 26, 2005
    9,033
    Western Sydney
    Gravity will affect it but we are talking about tiny tiny variations here, nowhere near a curve.
  9. scottath
    scottath Member
    Aug 16, 2007
    2,575
    Also have refraction of the light when hitting particles [water vapour etc] in the atmosphere
    Pianist
    Pianist Member
    Oct 7, 2005
    727
    so would the planet have to be light years in diameter for the light to bend around and come back?
    are there any formulas for calculating photon interactions with gravity?
  11. -KoMoD0-
    -KoMoD0- Member
    Dec 26, 2005
    9,033
    Western Sydney
    Wait for Goth to show up, he is the physics genius :)
  12. scottath
    scottath Member
    Aug 16, 2007
    2,575
    Very unlikely that the light would bend around at all - Actually probably impossible
    ????? I'm only in Yr11....so no idea - i would guess there is but the particles in the atmosphere would through it off - so if you went to a planet the same size as Earth but with no atmosphere the it would work [the gravity calcutlation - not the bend around the planet bit...]
  13. Whisper
    Whisper Member
    8,297
    No
    Just very massive, as in, has a lot of mass.
    Think black holes or neutron stars
    Actually, its not really possible to observe something that is capable of bending light back in the way you are describing.
  14. hlokk
    hlokk Member
    Jul 18, 2003
    5,123
    WA
    edit: light is affected by gravity (or more accurately curved space-time which is what gives the illusion of gravity), so it is possible
    The only way something would come full circle would be if you matched the speed to the orbital speed at that location (i.e. height). The speed is the square root of the gravitational parameter divided by the radius. The radius in the case of a light object (compared to the earth, as a heavy one would shift the orbit point) would be from the center of the earth to where the projectile left. Thats for a circular orbit, you could get elliptic orbits or whatever, which would hit you as well, but a little more complicated.
    (We'll assume no atmosphere and no rotation of the planet as you would have moved some amount by the time it made one revolution).
    Could you somehow be in space around a large object and fire a laser such that it orbits and hits you? Yes.
    Basically you need to be on the photon sphere. This is a sphere where tangential photons will orbit. You would find one around a black hole (1.5 times the radius of the event horizon radius, or swartzchild (sp?) radius). It is possible to have other non-black hole things do this such as a neutron star. I dont think you could stand on the surface though, as a planet made of atoms would have is diameter larger than the photon sphere radius (afaik). If you could stand on a pole (figureatively) jutting out of a suitable sized neutron star, or had a jetpack near the star or a black hole you could.
    edit: try some orbits here: http://www.mofunzone.com/online_games/orbit.shtml#
  15. scottath
    scottath Member
    Aug 16, 2007
    2,575
    That sort of made sense....
    Thanks for the impossible in site into life of a laser beam on a object we haven't yet reached.
    Seriously - that was interesting and very technical - thanks for the lesson
    EDIT: cool game :)
  16. hlokk
    hlokk Member
    Jul 18, 2003
    5,123
    WA
    Theres another game where you attack other people with gravity influenced rockets which is fun, and theres also a small java applet where you can create as many objects as you like at the same time, and you can wait for the bad orbit ones to weed themselves out.
    Keep in mind, the speed of light is fixed if you're playing the game while thinking about light (also, the masses would all be black holes or something)
  17. Menthu_Rae
    Menthu_Rae Member
    Mar 19, 2002
    6,874
    Northern Beaches, Sydney
    What the hell do they teach you kids in school these days? :p edit: added the tongue so it sounds like it should (i.e. not too serious)
    http://en.wikipedia.org/wiki/Corona
    http://en.wikipedia.org/wiki/Photosphere
    http://en.wikipedia.org/wiki/Chromosphere
    http://en.wikipedia.org/wiki/Solar_transition_region
    http://en.wikipedia.org/wiki/Stellar_atmosphere
  18. scottath
    scottath Member
    Aug 16, 2007
    2,575
    Whoops - your right
    Havent been there for 2 weeks any how - in holiday mode.....:confused::D:confused:
  19. Menthu_Rae
    Menthu_Rae Member
    Mar 19, 2002
    6,874
    Yeah yeah and I haven't been there for 5 years :lol:
    Anyway it's all good mate - even though it didn't sound like it - my post was kind of tongue in cheek.
    Was just letting you know that it does indeed have an atmosphere, albeit completely unlike our own ;) :thumbup:
  20. scottath
    scottath Member
    Aug 16, 2007
    2,575
    By atmosphere ealier i was refering to the particles in ours - like water vapor, CO2 etc that can/will refract the light of the said lazer
    No offence taken -
