SLI PROBLEMS
Discussion in 'Troubleshooting Help' started by Gaddo, Jul 22, 2010.
  1. Gaddo
    Gaddo Member
    Jul 21, 2010
    23
    i am running 2 x Gigabyte gtx 260 super over clocked cards
    mother board is a Gigabyte x58a-udr3
    cpu i7 920 running windows 7 64 bit
    power supply is 850w
    6gb of ram
    now when i had 1 card not a problem since i installed the 2nd card 3 weeks ago
    i am having the following problems i play MW2 BC2 BFV when maps change ect some times the screen goes black after 10 seconds or so it starts up again other times it crashes and i have to hit the reset button on the pc and reboot.
    other time the screen frezzes when im not playing games and have to reboot on average this happens once or twice a day
    does any one have any iders what this could be from ?????
    i am also running the single bridge for the sli on the closest connection to the back of the pc should i be running to twin bridge that is used for tri connection??
    sorry as i am a bit of a newbi to computers and building them
    any help would be much appreciated
  2. King Krapp
    King Krapp Member
    Jan 19, 2009
    2,639
    First off, uninstall your drivers, reboot into safe mode, run Driver Sweeper, reboot, install the latest drivers, reboot and see if that works.
    Exactly what brand and model is your power supply?
  3. Garido
    Garido Member
    Apr 12, 2010
    5,247
    Parramatta, NSW
    You could also confirm to test both graphics cards individually as well as testing the motherboard PCIe slots.
  4. RSDXzec
    RSDXzec Member
    Jan 4, 2009
    1,999
    Townsville, North QLD
    ... better not be shaw
    Gaddo
    Gaddo Member
    Jul 21, 2010
    23
    the power supply is an antec 850w
    i will do the above and get back to you thanks
  6. fang_laluna
    fang_laluna Member
    Sep 5, 2009
    1,183
    Second this.
    Re-seat the sli bridge, I had the exact same problem with 2 x gtx 285. It always crash with new drivers. Try 192 driver.
    Gaddo
    Gaddo Member
    Jul 21, 2010
    23
    Hey guys looks like what king krapp suggested has fixed the problem thanks very much for your help guys much appreciated
    if it still happens ill be back thanks again
    Gaddo
    Gaddo Member
    Jul 21, 2010
    23
    ok thought i had fixed the problem but its still happening any other iders
  9. fang_laluna
    fang_laluna Member
    Sep 5, 2009
    1,183
    Did you overclock both cards? Try them on default settings or give 186 driver a try
    Gaddo
    Gaddo Member
    Jul 21, 2010
    23
    no i have left them default were do i find the 186 drivers ??
    Gaddo
    Gaddo Member
    Jul 21, 2010
    23
    ok i tryed older drives but still no good any on else got any other iders ??
  12. OldnBold
    OldnBold Member
    Oct 5, 2004
    4,261
    Sunshine Coast
    Does the problem happen with a single card?
    Gaddo
    Gaddo Member
    Jul 21, 2010
    23
    no it does not one card the original card runs fine. yesterday i thought i would swap the cards around so the 2nd card my new one was connected to the display loaded up fine then i ran a few benchmark test in SLI and the display was all warped really bad colours ect so i disabled SLI so it was running of one card the new one and the display was still a bit warped one of the benchmarks it would fail after about 10 seconds. so i think the card is faulty i have pulled it out and i am going to return it to were i bought it.
    how do i prove it to them that it it faulty ?? im 100% sure know that that is why it was failing unless anyone else has any iders??
  14. Yamunsa
    Yamunsa Member
    May 24, 2009
    1,651
    Cairns
    just give it to them. they will test it and hopefully have the same fault.
  15. King Krapp
    King Krapp Member
    Jan 19, 2009
    2,639
    This, just tell them what you told us (Had a card, worked fine, introduced the new card, things went wrong, tried with the old card by itself which worked, tried the new card by itself which failed under benchmarks/games). They'll test it themselves and if the same thing happens (it will if the card is faulty), they replace it.
