Sliding mitre saw.
Discussion in 'Modding' started by DSTM (Dougie), Mar 24, 2019.
  1. Recharge
    Recharge Member
    Sep 5, 2001
    10,807
    roofing square? you mean the speed square?
  2. havabeer
    havabeer Member
    Dec 12, 2010
    5,475
    Engineers square on anything that ACTUALLY matters
  3. oculi
    oculi Member
    Aug 18, 2004
    11,155
    If it looks square it is square
    DSTM (Dougie)
    DSTM (Dougie) Member
    Jun 2, 2018
    612
    Western Sydney
    The very fine cut line in the centre tells me the angle iron is bowing slightly.
    Rule of thumb is the thinner the material, the finer the blade.
    You can still cut with a course blade, but the blade must be deeper in the ply to help prevent tear out.
    In your case I would be laying the ply on milk crates, using a straight piece of timber,as a guide ,and the saw will be deeper in the job, giving a much better cut, and minimun tear out.
    I think you are giving yourself a big headache, trying to make a jig, with a span over that distance.
    I think you would need to buy the same angle, and place underneath, and small welds to top angle, make into T-Section,if you are determined to build one.
    firey4059 likes this.
  5. Recharge
    Recharge Member
    Sep 5, 2001
    10,807
    yea, I was considering making it a T. or finding a better, more rigid shape.
    Edit
    well, it was a nice idea, but I've had to scrap the whole lot, the rails aren't strait and I don't think I can get them strait. doh.
    was a nice idea, but unworkable at that length.
    an idea though, a strait edge with milled slots along it so you can use a track clamp to slide in to clamp to work piece. then again, might be just as annoying as a standard clamp..
    ponder ponder.
    makes me really want a table saw more, but anything with a decent track in it is out of my budget.
  6. havabeer
    havabeer Member
    Dec 12, 2010
    5,475
    upside down circ saw in a piece of ply/MDF
    clamp a fence on and rip down to your hearts content. its a MORE fidly way of doing things especially getting square but its also VERY cheap
  7. Recharge
    Recharge Member
    Sep 5, 2001
    10,807
    I was thinking of doing something with this
    :D
    DSTM (Dougie)
    Jun 2, 2018
    612
    Western Sydney
    They look simple enough to make. Just watched this video.
    Make the table the size you require.
    DSTM (Dougie)
    Jun 2, 2018
    612
    Western Sydney
    Yes, that's humungus.Where in the hell did you get that.The best thing to do with that is strip it for Ally and copper.Looks bloody dangerous.:D
  10. Recharge
    Recharge Member
    Sep 5, 2001
    10,807
    it's from a cheap arse nasty GMC table saw that was so crap it was better to kill it with hopes to re purpose it, perhaps.
    it's not that big really, but it won't take much to make it unto a simple table setup, no more dangerous than a circular saw.
    DSTM (Dougie)
    Jun 2, 2018
    612
    Western Sydney
    Overkill using that GMC motor.For one it has no brake and the blade will take ages to stop.
    You need to decide what you are going to use,and go with that.:)
  12. Recharge
    Recharge Member
    Sep 5, 2001
    10,807
    if not as a saw, then no idea.
  13. havabeer
    havabeer Member
    Dec 12, 2010
    5,475
    Are you still after a saw. There's a 2nd hand "wesco" job site style one for $80 near me
  14. Recharge
    Recharge Member
    Sep 5, 2001
    10,807
    any details on it? model?
  15. havabeer
    havabeer Member
    Dec 12, 2010
    5,475
    Best I can give you
  16. Recharge
    Recharge Member
    Sep 5, 2001
    10,807
    ooohhhh! colour me interested! looks like it's possible to use a skid on it too.
    is this somewhere south side brisbane?
  17. GumbyNoTalent
    GumbyNoTalent Member
    Jan 8, 2003
    8,276
    Briz Vegas
    Most timber supply yards will cut to measure for free.
  18. Recharge
    Recharge Member
    Sep 5, 2001
    10,807
    in my current situation, requite 100mm strips of masonite, bunnincs won't cut under 300mm and have not been able to source material and cut anywhere else, exhausted all online options in south brisbane (of which there arent' many anyway)
    soooooooo yea.
  19. havabeer
    havabeer Member
    Dec 12, 2010
    5,475
    no, this is lake maquarie NSW.
    check out the facebook market place though, you'll be surprised what you find
  20. Recharge
    Recharge Member
    Sep 5, 2001
    10,807
    thats a little outside of my range :lol: and postage would be crazy! eek!
    but, thanks you very much for posting it up :D
    and yes, I'm a very regular on facebook market and gumtree looking for cheap toys.
