Sliding mitre saw.
Discussion in 'Modding' started by DSTM (Dougie), Mar 24, 2019.
  1. clonex
    clonex Member
    Jun 30, 2001
    22,439
    north pole
    once again cant remember the name but theres a mob in salisbury/coopers plains that cut stuff
    edit:
    http://www.woodnyou.com/
  2. Recharge
    Recharge Member
    Sep 5, 2001
    10,834
    sweet, many thanks!
  3. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,189
    Perth , East Vic Park
    Made myself one of these 2 weekends ago. Skipped the bit poking out the top and just cut the hanging hole onto the middle of the work surface . Pretty small and near the back so does not cause issues but saves space and wood. Used a bunch of scrap I had hanging around. Made has a bit over 50cm of cutting width and 65-70mm of depth .
    So easy to do, super cheap and very effective.
    DSTM (Dougie)
    DSTM (Dougie) Member
    Jun 2, 2018
    616
    Western Sydney
    Any Photos?:)
  5. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,189
    I used a longer narrower board cut in half as that is what I had on hand. I also used Alu T extrusion rather than L as it was cheaper and more ridged but I did need to trim one down to make space for the saw motor.
    Sure.
    Added the Router inserts as well
    mad_mic3 and DSTM (Dougie) like this.
  6. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,189
    Made this last weekend with the Jig. Turned out alright but I need to work on my planing skills.
    Made mostly from bulk collection scrap bar the wheels, screws which I bought or consumables which I had on hand.
    Made from mostly structural timber.
    Used the jig to cut everything to length as well and trimming the whole board once everything was glued and planed.
    juzz86 and shredder like this.
  7. RavenAU
    RavenAU Member
    Nov 23, 2018
    12
    Overthinking it,
    i cut perspex and acrylic for work every now and then.
    Freehand it with a circular saw, tidy it up with electric planer.
    Perfect straight cuts every time.
  8. Recharge
    Recharge Member
    Sep 5, 2001
    10,834
    I bet your work saw costs WAY more than a general handymans saw... pics?
  9. RavenAU
    RavenAU Member
    Nov 23, 2018
    12
    its a circular saw....
    Any brand. ozito will do. And i buy the cheapest blades i can find with lots of small teeth.
    Don't plunge the saw full depth, keep 4mm of the teeth extruding past the base that way your 'skimming off the plastic' and not ripping it on the way out. You can even cut it in reverse doing this.
    i have a battery operated milwaukee, also a corded hitachi.
    in reality any saw is a spindle that spins. doesn't matter if its $600 or $60. The blades do the work.
    Defyant likes this.
  10. Recharge
    Recharge Member
    Sep 5, 2001
    10,834
    and how DO you cut so perfectly strait? a strait edge or some such?
  11. shredder
    shredder Member
    Dec 26, 2001
    12,956
    New Zealand
    Sweet, I'll swap you my Ozito for your Milwaukee then. :D
  12. RavenAU
    RavenAU Member
    Nov 23, 2018
    12
    Electric planer. Works surprising well on perspex/Acrylic edges, and chews it quickly. Very easy to trim down a few mm.
    Gives a near perfect edge to that I would say you wouldn't even need to sand / finish. This may depend on your ocd.
    Perspex is one thing. I'd melt the ozito doing hardwood
    Keep in mind I wouldn't try to cut anything less than probably 200ish mm doing this. Even on a tablesaw. If Acrylic catches in the blades it's nasty. That's bandsaw / grinder / dremel time
    mad_mic3 and shredder like this.
  13. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,189
    Cutting sheets by hand with a circular saw is fine but smaller pieces is a bit janky. Especially if you are working with very short stock.
    The Jig makes it easy.
    DSTM (Dougie) likes this.
