so i'm an idiot and spilled water on my 3090
Discussion in 'Extreme and Water Cooling' started by aeries, May 20, 2021.
  1. Myne_h
    Myne_h Member
    Feb 27, 2002
    11,448
    I think it's probably the main mosfet driver/voltage regulator.
  2. jjjc_93
    jjjc_93 Member
    Jul 3, 2009
    3,616
    That was a fair bit of corrosion in the first photos and doesn't look like anything actually burnt out from a serious short so I would have some hope still now. Best of luck :thumbup:
    Make sure your motherboard is dry and clean too.
    From what I can find the ITE 8915FN ic is for fan control, makes sense with the proximity to the fan headers. Can't find a public datasheet for it.
  3. havabeer
    havabeer Member
    Dec 12, 2010
    6,883
    sending thoughts and prayers. awaiting the results
    newynut likes this.
    aeries
    aeries Member
    Dec 5, 2011
    1,410
    Hopefully it doesn't die...or hasn't died...
    Checking the mb now, I've been at it for a good twenty minutes and there isn't much corrosion left. Here's hoping...
    Update within the hour, just gonna give the card a blast of cool air and block it and see what happens...should i test for lights on PCIE first, or just fire?
    aeries
    aeries Member
    Dec 5, 2011
    1,410
    Oh no I heard a pop
    EDIT: but the lights for no PCIE power work fine...
    EDIT 2: no signal :(
  6. 151528
    151528 Member
    Jan 23, 2007
    1,286
    Vic
    BurningFeetMan and mAJORD like this.
  7. Myne_h
    Myne_h Member
    Feb 27, 2002
    11,448
    Multimeter time. If you're lucky, fuses. If you're not, good luck.
  8. Myne_h
    Myne_h Member
    Feb 27, 2002
    11,448
  9. hawpinghaxbag
    hawpinghaxbag Member
    Jun 6, 2005
    5,814
    Your mum's place
    Can confirm, insta killed a computer after i left a stop plug off after a coolant refresh
  10. jekel
    jekel Member
    Jul 24, 2004
    844
    Man unlucky....
    Hope something works out 3090 is a pretty big hit $$ to accept :(
  11. newynut
    newynut Member
    Jul 28, 2006
    782
    in depression over nbn
    Fingers crossed here.
  12. 151528
    151528 Member
    Jan 23, 2007
    1,286
    Vic
    Did you end up pming myne h about having a crack at fixing it?
    aeries
    aeries Member
    Dec 5, 2011
    1,410
    Yeh so the temporary solution was to get another 3090, systems running ok
    Ill figure something out for this card, put the stock cooler on again, might put it on a test bench and see if it goes, otherwise prob have to get it rmad or pray
    Me too mate :thumbup:
    I did, didn't get around to testing it with a multimeter, also talked to someone at asus rnd and he mentioned how polyfuses are supposed to work again after popping..tried again but its not working..
    After the alcohol wipes and drying out the card, seems like the power part is fine, but the card just won't display. Monitor shows DP, then it shows DP no signal
  14. Renza
    Renza Member
    Dec 1, 2004
    4,942
    :rolleyes:
    aeries
    aeries Member
    Dec 5, 2011
    1,410
    well it's not a guarantee to be accepted, right? :rolleyes:
    and if it doesn't, well i'll know to get an EVGA card next time :rolleyes:
    newynut likes this.
