Solar/12v power plug question
Discussion in 'Electronics & Electrics' started by dalai_yoda, May 19, 2016.
  1. dalai_yoda
    dalai_yoda Member
    Feb 19, 2006
    177
    I've seen the type of plugs seen here on a couple of solar/lighting setups. What is that specific plug type called? Is it a standard of some sort?
    dalai_yoda
    dalai_yoda Member
    Feb 19, 2006
    177
    Nevermind, think it's MC4. Correct me if I'm wrong!
  3. RobRoySyd
    RobRoySyd Member
    Jan 24, 2008
    8,251
    dalai_yoda
    dalai_yoda Member
    Feb 19, 2006
    177
    ah, yep, cool, ok. '12v DC connector' gets me what I want. 'plug' was screwing up search or something. Ta.
  5. RobRoySyd
    RobRoySyd Member
    Jan 24, 2008
    8,251
    Be careful, there's multiple slightly different connectors that could be "12V DC Connectors". You really need to know the outer barrel diameter and the inner pin diameter. The pin diameter really requires a calliper to measure.
  6. aXis
    aXis Member
    5,548
    Kalgoorlie, WA
    They are not even 12V specifically, or even DC. But yeah they are commonly used on low voltage 5V and 12V DC gear.
    The technical name is a barrel plug and barrel socket. They are generally labeled by the pin diameter, eg 0.7mm, 2.1mm, 2.5mm, 3.2mm. 2.1 and 2.5 are really hard to tell apart just by looking at them.
