Soldering assistance required in Perth
Discussion in 'Electronics & Electrics' started by Wozzernux, Sep 13, 2018.
  1. Wozzernux
    Wozzernux Member
    Aug 3, 2006
    824
    Perth, WA
    G'day folks,
    My X79 Sabertooth board has a damaged 8pin EPS12V power connector that needs to be replaced. I've sourced a donor board with an intact connector, but a local hobby shop couldn't desolder it :Paranoid: turns out mainboards use lead-free solder which requires much higher working temps!
    Does anyone in Perth have experience + equipment for such a task? Willing to travel anywhere in the Perth metro area :thumbup:
  2. shift
    shift Member
    Jul 28, 2001
    2,937
    Hillcrest, Logan
    Everything that's mass produced these days will be using lead-free solder.
    Adding leaded solder to the joint before trying to de-solder it should make it melt easier.
    Wozzernux
    Wozzernux Member
    Aug 3, 2006
    824
    Perth, WA
    Thanks to Joe at Gostronic in Perth for fixing my board :thumbup:
