soldering points on xbox 360 pad
Discussion in 'Electronics & Electrics' started by jay-stormchaser, Apr 14, 2009.
  1. jay-stormchaser
    jay-stormchaser Member
    Aug 10, 2007
    276
    I'm making myself an arcade stick for street fighter 4 by using an old 360 pad and after looking at the diagrams on the net I have noticed that mine are different.
    Here is the pic of what I have
    And here is the link to the site with the diagrams.
    http://www.slagcoin.com/joystick/pcb_diagrams/360_diagram1.jpg
    So if someone could show me where signal and common is on the pad or atleast tell me how to find it for myself.
    Thanks.
    Jason
  2. Ephphatha
    Ephphatha Member
    Mar 3, 2006
    108
    Bathurst NSW
    If you have a multimeter, put one prong on the contact for the black wire coming from the battery pack, and poke around the rest of the board testing for a connection, if you find two points that are connected, you've found your ground points. (Take the batteries out first though).
  3. Mjollnir
    Mjollnir Member
    6,313
    Melbourne, VIC3104
    U can see on the pic that tracks between pads X and A, Y and B are connected, and that's most likely your common ground. Just double check by following the tracks between pads and check connectivity with a multimeter.
