[SOLVED] Having issues deleting and recreating zfs pool
Discussion in 'Storage & Backup' started by cyrax83, Apr 29, 2013.
  1. cyrax83
    cyrax83 Member
    Feb 5, 2005
    5,074
    hurstville, sydney
    Had a 5 drive ZFS pool on raidz version 28 (solaris express 11). 1 drive died, 2 had SMART errors. Anyway finally got 3 replacement drives again.
    In napp-it, I tried to delete the pool (called micro2). It deleted and now no longer shows
    root@microserver2:~# zpool list micro2
    cannot open 'micro2': no such pool
    root@microserver2:~# zfs list micro2
    cannot open 'micro2': dataset does not exist
    But when I try to create a new pool in napp-it called micro2 I get : "oops... pool /micro2 already exist!"
    How do I get rid of this damn pool so I can recreate it? I can't see it anywhere.
  2. Stanza
    Stanza Member
    2,899
    What does zpool status show?
    cyrax83
    cyrax83 Member
    Feb 5, 2005
    5,074
    hurstville, sydney
    Doesn't show the micro2 pool, only rpool which is a separate OS drive
    pool: rpool
    state: ONLINE
    scan: none requested
    config:
    NAME STATE READ WRITE CKSUM
    rpool ONLINE 0 0 0
    c7t0d0s0 ONLINE 0 0 0
    errors: No known data errors
  4. klif-e
    klif-e Member
    Jun 26, 2001
    751
    Melbourne, Victoria, Aust
    I wonder if rather than destroy'ing it, it has exported it?
    This would mean the pool still exists on disk, but is not active within Solaris.
    You could try a zpool import and see if it re-finds micro2.
    Then correctly do a zpool destroy micro2.
    If not I not sure why it would think the pool exists when it doesn't.
    cyrax83
    cyrax83 Member
    Feb 5, 2005
    5,074
    hurstville, sydney
    Thanks, tried it but didn't work. Tried to create on command line with -f option and it worked :thumbup:
