[SOLVED]Mac osx - spacebar preview not working
Discussion in 'Other Operating Systems' started by Just5Mhz, Dec 15, 2014.
  1. Just5Mhz
    Just5Mhz Member
    Mar 25, 2013
    117
    Sydney, 2170
    Normally when I would press spacebar to preview an image, it would give me a full preview of it, like so:
    http://imgur.com/AeGvBix
    However now, it only gives me a very small version of the picture and a lot of wasted space:
    http://imgur.com/zZGqcsQ
    This does not happen with all images, ones which I have saved a while ago are still normal. Only ones which I have saved in the last two weeks or so have the above issue. I have tried googling but haven't been able to find a solution. I haven't run any updates, or installed any sort of software. I have compared the "get info" data of both an old and a newer image, all relevant information such as extensions is identical. Don't have any clue what to do here, must be an easy fix but I am just clueless. :confused::upset:
  2. plasticbastard
    plasticbastard Member
    Jul 30, 2003
    4,004
    Sector ZZ9 Plural Z Alpha
  3. junglist
    junglist Member
    852
    Launceston, Tasmania
    I can replicate this issue by removing the file extension and pressing space bar, but If I have already done a quick preview on the file before removing the extension it still works as normal. Very odd.
  4. karnophage
    karnophage Member
    Aug 29, 2011
    428
    6112
