Some Questions for Mini-ITX computer
Discussion in 'Other CPUs and chipsets' started by nelson92, Feb 23, 2008.
  1. nelson92
    nelson92 Member
    Feb 26, 2007
    585
    Sydney 2177
  2. SLATYE
    SLATYE SLATYE, not SLAYTE
    Nov 11, 2002
    26,852
    Mounting it upside-down will be fine. Just make sure that the PCI card (if you're using one) is firmly secured, so it can't fall out of the slot.
    That power supply should handle the mainboard, a HDD, and a few low-speed fans.
    nelson92
    nelson92 Member
    Feb 26, 2007
    585
    Sydney 2177
    thanks, and i wont be using a PCI card, im mounting this in a Car Amp that was faulty
    nelson92
    nelson92 Member
    Feb 26, 2007
    585
    Sydney 2177
    would the CPU overheat if the board was upside down? the CPU already idles at 50'C
  5. phreeky82
    phreeky82 Member
    Dec 10, 2002
    9,574
    Townsville
    The orientation makes no difference, but you're still leaving a gap between the fan and a surface aren't you? A few centimetres at a minimum IMO (or a grill/mesh/vent above it instead, or maybe a sideways blowing fan rather than the stock config).
    nelson92
    nelson92 Member
    Feb 26, 2007
    585
    Sydney 2177
  7. senilebob
    senilebob Member
    Dec 1, 2005
    3
    Beaconsfield, Vic
    That PSU will power your stuff fine. And yes, it will turn on and off with your car so long as you connect the ignition input to your cars ignition line.
    You might wanna try emailing the guys at www.mini-box.com.au for a cheaper price on the M3-ATX PSU.
