spilled water on pc, won't turn on
Discussion in 'Troubleshooting Help' started by NNNG, Feb 27, 2012.
  1. NNNG
    NNNG Member
    Sep 25, 2009
    1,722
    So I was a fucking moron and spilled water all over my desk, which then leaked all over my PC. Within two seconds I turned it off at the power point and then had my shirt soaking up the water on top of the PC. After opening up the case I found a little bit of water around the edges, like where the side panels touch the rest of the case - but there didn't seem to be any water on any of the hardware.
    Now it won't turn on. Should I leave it to dry for a day and then try again? Or start testing and cleaning individual components?
  2. Creekin
    Creekin (Taking a Break)
    Jun 21, 2003
    10,105
    dry it as best u can with paper towel and then a hair dryer if u cant get to any visible moisture
    then leave it to air over night
    but trying to start it wet or letting it run wet it may already be dead
  3. Madengineer
    Madengineer Member
    May 27, 2011
    15,484
    Take the large components out to let them dry on there own. Give it 24-48 hours to dry out. Shouldnt take long in this heat. Then inspect it for damage. IE burns/blisters etc
    NNNG
    NNNG Member
    Sep 25, 2009
    1,722
    Will a computer turn on with no graphics card?
  5. Creekin
    Jun 21, 2003
    10,105
    it will boot and beep error msgs
    NNNG
    NNNG Member
    Sep 25, 2009
    1,722
    The PSU can at least by jump started with a paperclip and can power some fans. I think it is OK.
    Unplugged everything except the CPU, CPU fans, a stick of RAM, 24 pin mobo connector, EPS 12V connector, then tried turning it on by shorting the pins on the mobo. Still didn't turn on. So I removed the motherboard and can spot no water and no signs of damage.
    Any ideas?
    NNNG
    NNNG Member
    Sep 25, 2009
    1,722
  8. Creekin
    Jun 21, 2003
    10,105
    bummer :thumbdn:
    but u said in the op u dont think any water touched the hardware.
    was it a lot of water that u spilt?
    with any luck ur cpu/ram etc will still be fine
    grab a cheap mobo off the forums ftw :thumbup:
  9. Marksman X
    Marksman X Member
    Jun 5, 2010
    1,832
    Perhaps turning it off at the wall before the PC powered down has contributed.
    Have you tried a different PSU?
  10. Creekin
    Jun 21, 2003
    10,105
    :confused:
    that hasnt been a problem since win98 era hw... :p
  11. Marksman X
    Marksman X Member
    Jun 5, 2010
    1,832
    ^^ The dude was covered in water when he flicked the switch :thumbup:
    NNNG
    NNNG Member
    Sep 25, 2009
    1,722
    It was about a glass (tall glass) worth of water that spilled on the desk, much of which ran down and landed on the computer. Some if it got inside but I didn't find any water on any hardware itself, just around some parts of the case. None of the hardware appears to be damaged.
    I have a dead P5B Deluxe that won't post, when I plugged the PSU into that and tried turning it on, it could at least turn the PSU on (fan spinning), the lights turn on etc... The PSU can also be jump started no problem with a paper clip (connect the green wire and the black wire) and can run a few fans. I'm 75% sure the power supply is fine. With the P35-DS3P? Nothing happens, at all, when attempted to be turned on.
    I'll try testing the RAM later, GFX card, SSD, etc later.
    I was pretty dry when I flicked the switch. Two seconds later I took my shirt off and started drying.
  13. GeneralDeath
    GeneralDeath Member
    Sep 9, 2011
    423
    Spitting Chips mate hope all you're parts are still a ok etc Ram and CPU and SSD ohh and GPU. Fingers crossed the board just is dead.
  14. ppantel
    ppantel Member
    Nov 18, 2011
    153
    Brisbane, QLD, Australia
    just blow dry it and it should be fine. sounds like your psu is dead through?
  15. Creekin
    Jun 21, 2003
    10,105
    sounds weird that its dead if u dont think it got wet,
    but yeah id be stripping it down, checking every part for signs of water damage, and then testing with known good hw.
    GL :thumbup:
  16. HeXa
    HeXa Member
    Jul 7, 2001
    10,211
    Canberra, ACT
    I've had a few mobos in the past which go into shitty boot guard fail safe modes when mains power is lost
    they take a minute or so to do their boot/reboot shit before completing a boot to OS
  17. Creekin
    Jun 21, 2003
    10,105
    ahh yeah theres a bios setting for that, but just pulling the power shouldnt kill modern hw.
    it must have got some water in it somewhere
    op has a drinking problem.. :lol:
  18. HeXa
    HeXa Member
    Jul 7, 2001
    10,211
    Canberra, ACT
    true - I pull mains plugs all the time on my shit boxens - really should connect a switch to the mobo :p
    OP's problem is they need to be drunk before attempting a strip down and reassemble
  19. BlueRaven
    BlueRaven should just have a blog.
    Jul 29, 2010
    7,275
    It sounds like either the mobo won't pass the PS-ON signal to the PSU (via the green wire in the 24-pin ATX) or the +5VSB rail in the PSU is dead (which means no standby power to the mobo to supply the PS-ON voltage).
    More likely to be the former than the latter i'd say, since most modern PSUs derive +5VSB from one of the +12V rails. If the pin-shorting trick turns on the PSU with a bit of a load on it, it's probably ok.
    OP, does your mobo have an onboard power switch? If yes, have you tried it? Unlikely to make a difference since any onboard switch would just be in parallel with the FP header, but you never know....
    I suspect you're up for a new board though. :(
    NNNG
    NNNG Member
    Sep 25, 2009
    1,722
    AMD E350 does a good job of replacing sig rig for the internet. :)
    Nah.
    Been on holidays for like 5 months so my sleeping patterns are broken. Started uni for the year on monday which meant I had to get up at 6AM (i.e. usually the time I go to bed). So I was extremely tired and not paying attention.
    Ironic that an electronic engineering student kills his computer that has been overclocked the hell out of because he spilled water on it. :p
    Nope. Thanks for the reply.
