Spilt tea on laptop
Discussion in 'Troubleshooting Help' started by Cinnamonbun, Nov 15, 2021.
  1. Cinnamonbun
    Cinnamonbun Member
    Mar 24, 2021
    4
    Hey all,
    My partner has spilt tea on her laptop. The battery is internal but it was switched off instantly.
    I have placed it upside down on top of some absorbent towels. Is there anything else I can do or should be doing?
    Kind regards,
    Eric
  2. fad
    fad Member
    Jun 26, 2001
    2,619
    City, Canberra, Australia
    Take it apart and clean liquid out of it. Depending on how much went it, it might be ok.
    Cinnamonbun likes this.
    Cinnamonbun
    Cinnamonbun Member
    Mar 24, 2021
    4
    Thank you! It is a dell inspiron laptop, and I have just downloaded the disassembly manual. Should I be worried about ESD and the like or are laptop components fairly robust?
    Dumb question but, should I start immediately?
    Cheers :)
  4. havabeer
    havabeer Member
    Dec 12, 2010
    6,942
    Call a priest.
    Honestly, let it dry for a few days if you can, but i think you'll be fine
  5. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    160,560
    Omicron Persei 8
    And don't bother with the old rice trick, as above just open her up, get as much liquid off as possible and let it air out over a couple of days. Might need to take all the keys off and clean them out otherwise sticky keys :p
  6. Optimus.
    Optimus. Member
    Jun 27, 2002
    6,707
    Was it black tea or white tea?
    Cinnamonbun
    Cinnamonbun Member
    Mar 24, 2021
    4
    Black tea... with milk...
  8. Optimus.
    Optimus. Member
    Jun 27, 2002
    6,707
    Ah, well no use crying over it then.
    Cinnamonbun
    Cinnamonbun Member
    Mar 24, 2021
    4
    AHAHAHA thanks, will it be okay?
  10. Optimus.
    Optimus. Member
    Jun 27, 2002
    6,707
    :lol:
    If your partner turned it off straight away, rather than it turning itself of, there's a good chance of recovery.
    If you have the skills, try opening it up and looking where the tea might have gone. If you can see splashes and stains, clean them with a cotton tip (especially if they are on metal traces on the motherboard). Blobs of milk or biscuit might be conductive... If it looks like it's around the RAM or HDD, take them out too for a once-over. But if it's just tipped on to the keyboard, that's not so bad and you much just have to deal with some gummy keys until you clean it up.
  11. de_overfiend
    de_overfiend Member
    Jul 12, 2001
    2,526
    Gold Coast
    i have tried with tea and coke and rum and bourbon and even water spills - end result is always the same
    pulled apart completely and cleaned with circuit cleaner etc and might work for a while or not turn on at all. if it does work it wont work for long...
    best bet is to pull the hdd and see what you can recover (if anything) and buy a new laptop - it will never be the same again.
    MR CHILLED likes this.
  12. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    160,560
    Omicron Persei 8
    Definitely! And something I forgot to mention, if it does operate normally again then secure important hard drive files first before anything else.
  13. Groff
    Groff Member
    Jun 22, 2012
    347
    NSW
    You'd be surprised where liquid accumulates in a laptop.
    As suggested, you really need to pull it apart and clean with iso or contact cleaner.
    I found water pooled inside a 2.5" ssd in a laptop that had a liquid spill.
    Lucky it was an SSD and not spinning rust (literally!).
    You may find you need to replace the keyboard as liquid can short the contacts.
    Dell, thankfully, have excellent manuals on their support page where you enter your service tag, that explain in detail how to disassemble/assemble your laptop.
  14. sebthepleb
    sebthepleb New Member
    Nov 8, 2021
    10
    Kwinana, WA
    "jUsT pUt It In RiCe!!1!"
    To be real though you may need to pull it apart and hand dry it/clean it.
  15. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    160,560
    Omicron Persei 8
    Similar places to your lunch bread crumbs I imagine.
  16. Green Apple
    Green Apple Member
    Mar 3, 2016
    30
    I’ve seen so many laptops survive ridiculous liquid damage with a prescription of isopropyl, time, effort and some work if you can open it up and clean up. Or alternatively you could try take it to a repair place if you’re not comfortable.
