I couldn't digitally upgrade my account either, same result as you. Ended up getting a mate to pick up a few retail copies, and upgraded our accounts that way.
Pretty sure you can use shift queues as well, so if you had 4 selected, hit shift+y then clicked 4 targets while holding shift it'd blast those 4 targets.
is there a built in way to check framerates? been a bit slow doing online play (waiting for all the beta platinum people to do their placement matches ) did my first placement match last night. Me-Protoss vs Zerg (dboy i think his name was...sorry if that is someone here ) Game starts with him saying "glhf" and then "i'm noob". yeah right! when i went to expand to my natural, he had a hatchary and ~6 zerglings guarding it, i had ~4 zealots so easilly took it out. did some strafing runs with mutas into my base to take out my drones, but i had almost exhausted everything anyway. Ended up beating him fairly easilly, but really, resorting to saying things like "im noob" to try and get the other person to go easy on you so you can win is pretty sad!
I am currently running Mac OSX and Windows 7. Is it possible to install this game on both operating systems?
As long as the game supports OSX you can. If you're talking about from the one copy of the game, then yes. The game doesn't authenticate when you install, it's authenticated when you login to battle.net, as the game is connected to your battle.net account. You can't play on both the Mac and the PC at the same time.
hey guys, i'm creating a unit list of all the races on the wiki cause I'm having a hard time finding the info I need on the net in the one place. if you know any of the info for the tables, feel free give us a hand and chuck it in!
Should add a column for armour type and damage i.e colus = armoured, massive Thor do 14dmg vs light, 7 normal for air attacks (something like that anyway)
Instead of what units good against terran, protoss, zerg etc. Maybe make it what theyre good against and week against (For example Vikings good against armoured, Reapers good against light, bad against armoured etc)
