Start menu... not in alphabetical order
Discussion in 'Windows Operating Systems' started by maxwolfie, Nov 19, 2008.
  1. maxwolfie
    maxwolfie Member
    May 2, 2004
    2,359
    Newcastle, NSW
    Ok, I know this can be fixed by deleting a registry key, or something similar.
    However, what I want to know is (other than what key) is if a script or something similar can be installed so that the key is deleted on every windows startup
    Or better yet, a program that somehow arranges the start menu in real time.. after the app has been installed
    It's driving me nuts the way it is
  2. Rezin
    Rezin Member
    Oct 27, 2002
    9,490
    You must be using XP... Vista doesn't have this problem (AFAIK).
    This link might be helpful. Basically makes the key read-only so it can't be modified when you logout.
  3. NismoR31
    NismoR31 Member
    Aug 3, 2006
    4,220
    right click > sort by name
  4. Knight Of Nih
    Knight Of Nih Member
    Mar 23, 2003
    400
    Darwin
    yeah whats the problem with using this? or do you just want it to be automatic?
    maxwolfie
    maxwolfie Member
    May 2, 2004
    2,359
    Newcastle, NSW
    Automatic! :thumbup:
  6. timace
    timace Member
    Aug 6, 2003
    1,784
    yeah, he's after an automagic method.
  7. Assasinator_2
    Assasinator_2 (Banned or Deleted)
    Dec 11, 2002
    4,585
    Rockhampton
    Why are you installing new stuff every system startup? Is it really that hard to do 2 clicks once every month or something when you install a new application?
    I just don't get why you'd need to do it so much to automate it :confused:
  8. lazer1
    lazer1 Member
    Feb 25, 2004
    329
    I know killing explorer.exe and reloading it will probably force a refresh but this is a bit ugly :)
  9. Drunkmunky
    Drunkmunky Member
    Jun 20, 2006
    1,847
    Hobart
    I assumed this was Microsofts intended way of doing things since it seems to be required so regularly -_-
