Static through headphones
Discussion in 'PC Audio' started by Nedstark, Nov 25, 2015.
  1. Nedstark
    Nedstark Member
    Jul 20, 2014
    23
    Hey ocau.
    In need some sound help. I own a pair of corsair h1400s and recently i have had a large amount of static building up through the mic. When i say build up, its like it starts off low and over about 3 seconds builds up to full white noise. I am currently using a splitter to seperate mic and headphones, and just using onboard sound. The headphones/mic works fine on any other pc without the splitter.
    Is this a mobo issue? Or is it a headphone issue? Or is this a common problem?
    I need help before my mates on skype turn on friendly fire..
  2. zero_velocity
    zero_velocity Member
    Sep 16, 2010
    2,883
    QLD
    Its probably the auto level adjust of skype causing the issues
    Edit: Speaking from first hand experience here, if you are quiet for a while it will build up and pick up noise around you as you have described
    Nedstark
    Nedstark Member
    Jul 20, 2014
    23
    Thanks. I shall try this and give it a go. Must just be some setting with my sound and skype together.
