Statts' Not-So-Ugly Drum Smoker
Discussion in 'Geek Food' started by Statts, Mar 17, 2015.
Thread Status:
Not open for further replies.
  1. AzonIc
    AzonIc Member
    Jan 7, 2002
    1,373
  2. Havabigjuan
    Havabigjuan Member
    Jul 2, 2001
    1,520
    5126 SA
    Damn, is a little out the way but tempting.
    Dunno what the Mrs would say about me coming home with them.....
  3. scon
    scon Member
    Sep 14, 2005
    5,221
    San Mateo, CA
    Not sure if the keg would work as well - though you could work around it. Do something similar to the Weber Smokey Mountain and put a water bath between the firebox and the grill.
  4. mmBax
    mmBax Member
    Oct 26, 2011
    3,272
    Following for interests sake - I was looking at buying something, if I can do it on the cheap I'm all over this.
  5. Havabigjuan
    Havabigjuan Member
    Jul 2, 2001
    1,520
    5126 SA
    same, to make or not to make.....
    Statts
    Statts RIP
    Aug 29, 2004
    2,504
    Radelaide, SA
    Come on guys, MAKE!
    For small smokers, get a Smokey Joe (there was one on Gumtree in SA not long ago, see if it's still there) and there's a certain size of big soup pot that fits right in, cut the bottom out and you have yourself a mini bullet smoker!
    Progress wise - Still waiting on the plumbing fittings to finish, and to paint the lid. Tonight I put in the air tight conduit fitting for the temp probes, and siliconed around all the bolts and nuts inside the drum. All things being equal, I'm on track to smoke up some ribs this weekend!
  7. mmBax
    mmBax Member
    Oct 26, 2011
    3,272
    Have you mentioned where you found the drum?
    Semi small town here I can't imagine them being too easy to come across. I'll make some calls tomorrow, but what kind of place did you get yours from? Metal recycler or something, approximately how much?
    Statts
    Statts RIP
    Aug 29, 2004
    2,504
    Radelaide, SA
    Yeah just a metal salvage place (Paramount Browns in Adelaide). $17 for a food grade drum (ex Orange concentrate from Coca Cola factory). Food grade drums do require the liner inside to be burnt+stripped or sand blasted out though. But the fact they havent had harsh chemicals in them is worth the effort.
  9. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    155,705
    Omicron Persei 8
    Paint job came out fantastic from what I can see in the pics :thumbup:
  10. AzonIc
    AzonIc Member
    Jan 7, 2002
    1,373
    What's the benefit in using a Weber lid over the lid that comes with the barrel (with modifications)
    Is it just the additional height - or is there something else?
  11. Rezzix
    Rezzix Member
    Jun 18, 2014
    228
    Melbourne, Austraila
    Yeah probably the additional height for one, your top grill rack can be almost level with the top of the barrel, so you won't need stick your head over the smoke to load it?
    Statts
    Statts RIP
    Aug 29, 2004
    2,504
    Radelaide, SA
    Teaser pic :lol: Not far off now....
  13. Havabigjuan
    Havabigjuan Member
    Jul 2, 2001
    1,520
    5126 SA
    you using Stag to seal the penetrations?
    Statts
    Statts RIP
    Aug 29, 2004
    2,504
    Radelaide, SA
    Nah, this gear here
  15. Havabigjuan
    Havabigjuan Member
    Jul 2, 2001
    1,520
    5126 SA
    cool, F'n hate Stag! :leet:
  16. mmBax
    mmBax Member
    Oct 26, 2011
    3,272
    Cheers for that, looking pretty awesome with that latest update. I made some calls on Friday and none of my local metal recyclers had anything food grade. I'll keep on it though.
  17. Turnip Dude
    Turnip Dude Member
    Feb 19, 2011
    405
    Perth WA
    When it's finished, how much would you consider selling it for? Would you consider making another one to sell to someone? Would you consider setting up a small business making them for sale? Go on Shark Tank!
  18. AzonIc
    AzonIc Member
    Jan 7, 2002
    1,373
    Nice work and awesome looking paint job
    I'm going to go buy my drum on Monday from PB's
    Statts
    Statts RIP
    Aug 29, 2004
    2,504
    Radelaide, SA
    I'd consider it if someone really wanted it done and didn't have the tools / skills. Would never look at it as a commercial venture though.
    Cheers, I'm really happy with how the paint came out in the end. Am currently prepping the lid for paint today.
    Good to hear you're going to have a crack at making one. One thing you might have trouble finding in Adelaide is suitable material for making your charcoal basket, at small quantities. I picked up a whole sheet of 50x25 steel mesh (not galv obviously). It has some surface rust, but that's going to happen to a fire basket anyway. If you need some, I can cut whatever size you need for $6pack. Look out for pics of the charcoal basket when it's finished tomorrow night to get an idea of what it's like. You'll probably 13" high by just over a metre in order to wrap around a 13" weber grate, if that's what you're planning.
  20. AzonIc
    AzonIc Member
    Jan 7, 2002
    1,373
    That would be great; thanks - I'll keep an eye out for the pics
    I really liked how the Big Poppa Smokas basket can be set on different levels; but then I won't be grilling on this so don't need that.
Thread Status:
