Storage Spaces = Parity speed increase
Discussion in 'Windows Operating Systems' started by LostBenji, Nov 7, 2012.
  1. LostBenji
    LostBenji Member
    Oct 5, 2007
    6,084
    Up a tower somewhere....
    For those wanting to see some reasonable speeds with Parity in Storage Spaces:
    <Storage Pool Name> = the Pools name, remove the < >
    Smaller disk-count arrays are always likely to be slow write, using bigger arrays of 6-8 drives will see decent speeds.
  2. Nhutty
    Nhutty Member
    Jun 6, 2003
    455
    going to try this tonight, thanks for the tip!
    created a 3 drive storage space last night and did notice awefully slow transfer speeds to it (under 30MB/s) so hopefully this will give me full speed again
  3. UserInterface
    UserInterface Member
    Jan 13, 2011
    360
    Thanks worked it out.
  4. UserInterface
    Jan 13, 2011
    360
    No sure if it make a big enough difference here's my results.
    Before any changes are made:
    After PS change made:
    After PS change and a reboot:
    LostBenji
    LostBenji Member
    Oct 5, 2007
    6,084
    I have removed my content.
  6. UserInterface
    Jan 13, 2011
    360
    haha, yeah it's a storage space so it's thin provisioned. I have about 6-7 3TB WD Green drives. Would be nice even if it was that slow to have 50TB just sitting there.. Not that I could ever fill it up.
    LostBenji
    LostBenji Member
    Oct 5, 2007
    6,084
    LostBenji
    LostBenji Member
    Oct 5, 2007
    6,084
  9. UserInterface
    Jan 13, 2011
    360
    Has anyone used StableBit DrivePool?
    I wonder if this is any better but don't have the drives to test it on..
    LostBenji
    LostBenji Member
    Oct 5, 2007
    6,084
  11. elvis
    elvis Old school old fool
    44,218
    36MB/s on a 5 drive stripe? :lol:
    LostBenji
    LostBenji Member
    Oct 5, 2007
    6,084
  13. elvis
    44,218
    8 commodity SATA disk RAID6 on low end hardware using Linux software RAID yields ~500MB/s reads, ~300MB/s writes.
    Storage spaces is a bad joke. Stick to FreeNAS if you want easy storage at home.
    LostBenji
    LostBenji Member
    Oct 5, 2007
    6,084
    I have removed my content..
  15. styluspilot
    styluspilot Member
    May 16, 2002
    395
    Seeing as this is related,
    I have been playing with Storage Spaces today and like others the first thing I noticed was the abysmal performance with parity spaces by default.
    I have since done 2 things,
    1. Enable Power Protected mode
    Set-StoragePool -FriendlyName <Storage Pool Name> -IsPowerProtected $True
    2. Added 2x SSD's as a dedicated journal
    The write speeds went from a horrible 25MB/sec to 90MB/sec getting close to what I was with using FreeNAS on the same hardware (this was just testing copying a file over SMB so my own machine and network (1GB NIC) were the limits here, will be using something like ATTO later on to compare.
    What I don't get is, from the Microsoft documentation it says you need to scale the number of journal drives with the number of parity spaces (columns)
    and of course you need to x2 on the journal drives as they are mirrored.
    Does this mean that If I create:
    • A Virtual Disk with 2 Columns I need 4x SSD's for a journal
    • A Virtual Disk with 6 Columns I need 12x SSD's for a journal
    That seems a bit extreme and makes ZFS + L2ARC/ZIL much more efficient, not to mention better performing.
    EDIT: OR, are they referring to journal per parity space, (ie Single, but can be Dual in 2012 R2)
    so would be 2 SSD's for a single parity space and 4 SSD's for a dual parity space.
    LostBenji
    LostBenji Member
    Oct 5, 2007
    6,084
    I forgot I had this thread here, nice NECRO buddy.
    As for the SSD caching, I don't bother with them as I have better uses of my SSD's.
    I have 2x 8-drive arrays, both each see 85-95MB/sec writes with 400+ reads.
  17. Grvm
    Grvm (Banned or Deleted)
    Oct 26, 2012
    141
    Those speeds are pretty ordinary, on a hardware card (9265) on a 8 drive raid 6 I see around the 950 MB's read and around 700MB's write.
    That's sequential, random read/write drops it a fair bit (as you would expect)
  18. luke o
    luke o Member
    Jun 15, 2003
    3,694
    WA
    Played with storage spaces, seems like cancer to me. Just couldn't get it going nicely. Ended up building a 10TB FreeNAS box, been solid, reliable and fast (saturates dual gigabit intel NIC's streaming to multiple PC's without issue).
  19. fad
    fad Member
    Jun 26, 2001
    2,542
    City, Canberra, Australia
    I found that too
