Store build with free delivery vs self-build & dozens of components with courier fees?
Discussion in 'PC Build Logs' started by Crewcut, Sep 20, 2020.
  1. Crewcut
    Crewcut Member
    May 22, 2020
    231
    Hi all,
    Coming from an Apple background into PC I've never done a home build. It kinda makes me nervous. But I'm wondering - do computer parts suppliers do free delivery? Because otherwise isn't freight on heaps of different parts going to add to the cost of a home build, chipping away at any savings you might make compared to just getting a shop with warranty to do it for you?
  2. macktheknife
    macktheknife Member
    Jul 26, 2005
    1,603
    If you're new to PC building then it's probably better to discuss a build directly with a trustworthy builder (eg Scorptec, PCCG)
    Crewcut likes this.
    Crewcut
    Crewcut Member
    May 22, 2020
    231
  4. macktheknife
    macktheknife Member
    Jul 26, 2005
    1,603
    You'd be better off with scorptec since PCCG doesn't have any presence in Sydney which could make warranty/service a problem in the future.
    Crewcut likes this.
    Crewcut
    Crewcut Member
    May 22, 2020
    231
    Thanks Mack.
  6. power
    66,072
    if dozens of redditors and Geralt can do it so can you.
    pc building these days is pretty much Lego.
    rireland and Crewcut like this.
    Crewcut
    Crewcut Member
    May 22, 2020
    231
    Cheers. If I get someone else to do it - it's probably due to a sense of urgency with certain projects I want to get underway.
  8. T1tan
    T1tan Member
    May 8, 2002
    6,114
    2607 / caaaaanbwa
    it's easier than you think - you can't plug in the wrong thing to the wrong thing anymore or short out a cpu with the wrong manual jumper - it's like those square goes in square, circle goes in circle things now.
    You have a choice: go intel or amd. Then from there just set your price range and this forum can guide you through what you want. Building takes less than a day to the unintiated. Unless you drop something on the motherboard (and even then, maybe not) you won't be able to screw anything up. But you might just want a pre-packaged option, they're just as good.
    Crewcut likes this.
  9. macktheknife
    macktheknife Member
    Jul 26, 2005
    1,603
    Motherboard case headers can.
