Strange internet problem
Discussion in 'Networking, Telephony & Internet' started by juscal, May 20, 2010.
  1. juscal
    juscal Member
    Dec 11, 2008
    872
    Victoria
    So it seems this evening several programs are unable to use the internet. Firefox can access the internet easily, IE cannot. Google Earth cant connect to it's server, but Adaware and AVG can connect to their servers and acquire updates.
    Strange, any suggestions?
  2. Airquarious
    Airquarious Member
    Aug 31, 2001
    1,801
    Galaxy near you!
    Restart the Comp.
    Disable AVG FireWall or any other FW...
  3. -Sk3tChY-
    -Sk3tChY- Member
    Oct 27, 2007
    3,967
    NSW, In a house.
    Restart the comp as said above, you could possibly have some dodgy resolutions stored in your DNS resolver cache and a restart will flush it.
    Alternatively do ipconfig /flushdns from a command prompt.
    It's a slim possibility, but is symptomatic of what you're saying, other than that chances are you're firewalls may be blocking programs/ports, so as said above - Disable them all and see how you go.
    juscal
    juscal Member
    Dec 11, 2008
    872
    Victoria
    Restarted computer several times, and have flushed DNS. Had a looky in the hosts file and nothing looks wrong. Currently running a Windows Defender scan, Adaware and AVG.
    Also disabled Windows Firewall, nothing changed.
    Any other suggestions?
  5. NeXuS
    NeXuS Member
    542
    Southern Suburbs, Melb
    Run a HiJackThis scan, take out any Internet Explorer plugins/BHO's that you dont use.
    juscal
    juscal Member
    Dec 11, 2008
    872
    Victoria
    Downloading HJT now. WLM is now refusing to work now aswell. Basically the only program that can acess the internet now is Firefox.
  7. Airquarious
    Airquarious Member
    Aug 31, 2001
    1,801
    Galaxy near you!
  8. yanman
    yanman Member
    Jun 4, 2002
    6,587
    Hobart
    Make sure you have space free on C:\
    I ran out totally (PeerGuardian was making a huge log file) and all sorts of weird things started happening including no web browsing.
  9. round
    round (Banned or Deleted)
    Apr 7, 2007
    15,474
    /pol/
    format c:
    time to start again...
  10. aza2001
    aza2001 Member
    Sep 14, 2002
    2,016
    Northmead
    reset your IE config
    Tool --->internet options ---> advance tab ----> reset (backup any bookmarks/ fav's if you wish)
    good luck:thumbup:
    juscal
    juscal Member
    Dec 11, 2008
    872
    Victoria
    I wouldnt think it would be something outside internet explorer because multiple programs are affected?
  12. bugayev
    bugayev Whammy!
    May 15, 2003
    4,093
    Some applications look to IE for their configuration. If IE has somehow gone a bit screwy it can pass through.
  13. yanman
    yanman Member
    Jun 4, 2002
    6,587
    Hobart
    I would be checking C: for space still. As I said it can do weird things when there's 0 free
  14. BOB_LORDOFEVIL
    BOB_LORDOFEVIL Member
    Jul 17, 2001
    1,280
    Personally I'd force DNS on the NIC. AVG afaik uses the IP to connect to their update server which is why it's working and the rest aren't.
  15. CordlezToaster
    CordlezToaster Member
    Nov 3, 2006
    4,069
    might be your isp check there forums or check whirlpool
  16. ConlMaggot
    ConlMaggot Member
    Dec 2, 2008
    495
    Linux live disc would tell you if its hardware/network bassed, or something screwy with your windows setup..
    I re-image my main windows machine once every 6 months, just to avoid shit like this.
  17. davos1
    davos1 Member
    Jan 8, 2009
    14
    Go to IE and make sure you have a proxy configured/disabled, whichever you need. The proxy setting in IE affects most other programs.
  18. aza2001
    aza2001 Member
    Sep 14, 2002
    2,016
    Northmead
    mybad didnt read it properly last night ...
    juscal
    juscal Member
    Dec 11, 2008
    872
    Victoria
    Thanks for the help guys. Turns out it WAS Internet Explorer. Took the advice of resetting the settings and its good as gold.
    Cheers guys.
