Substitute for 35V 56uF capacitor - have some spares ...
Discussion in 'Electronics & Electrics' started by bYrd, Apr 20, 2021.
  1. bYrd
    bYrd Member
    Sep 14, 2001
    2,290
    NE Melbourne
    Hi,
    I'm restoring a PSU from a Mac IIsi, have found replacement caps for most, bar a 35V 56uF capacitor which I think acts as a bypass capacitor. All the caps have leaked an absolute mess, but I'll press on and see if a recap and deep PCB clean does the trick.
    Locally, there aren't very close matches for 35V 56uF. I have on hand some good quality 50V 47uF caps (and also found a 50V 10uF part); in parallel would these suit - or just leave the one 50V 47uF noting what might be "good enough" +/- 10% tolerance?
    Thanks
    JB
  2. paulvk
    paulvk Member
    Mar 10, 2010
    1,082
    What type of capacitor is it , if an electrolytic then 47uF should be ok.
    The most important rating can be the internal resistance if its a switch mode power supply not the capacitance.
    bYrd
    bYrd Member
    Sep 14, 2001
    2,290
    NE Melbourne
    Yes, electrolytic. Thanks for confirming.
    The more I read about soldering capacitors in parallel it appears a poor solution.
  4. pfrcom
    pfrcom Member
    Aug 23, 2009
    448
    3114, Melbourne
    bYrd
    bYrd Member
    Sep 14, 2001
    2,290
    NE Melbourne
