Sunrise - Help me choose!
Discussion in 'The Gallery' started by kryzak260, Apr 22, 2012.
  1. kryzak260
    kryzak260 Member
    Sep 30, 2002
    2,335
    London Gov'na
    Hi Guys,
    I have a friend that got married today, and as my gift to them, i wanted to get a shot of the sunrise this morning which i will have printed and framed (or stretched canvas). I have narrowed it down to two photos that myself and my partner like but cant decide between them. Im leaning toward the long exposure one, because it feels more dynamic and more like something i would put on my wall, whereas my partner likes the other shot but cant tell me why.
    Matilda Bay Sunrise by Michael Tingey, on Flickr
    10-Stop Matilsa Bay Sunrise by Michael Tingey, on Flickr
    What do you think? And which framing method do you think suits these images best (print and frame, or stretched canvas, or other)?
    Cheers,
    Michael
  2. a1ring23
    a1ring23 Member
    Nov 30, 2010
    240
    Perth, Western Australia.
    I like the feel of #2 better but don't like the vignetting - not suited to landscapes IMO, but that's a very personal thing
  3. Frozen_Hell
    Frozen_Hell Member
    Sep 11, 2002
    2,946
    I agree, #2 without the vignetting imo. And I might just crop off that building on the far left hand edge of the photo if it was me.
    In terms of framing, I'm a fan of proper framing behind glass.. canvas has only gotten popular because people can blow up low detail digital shots into a large size and you don't see the lack of detail on canvas as much because of the coarse texture.
  4. ElBeasto
    ElBeasto Member
    Nov 3, 2004
    2,906
    The second one definitely for me too.
  5. Zee
    Zee Member
    Oct 27, 2002
    10,009
    SYD/MNL/SIN/SFO
    +1 to all the above.
    Z...
  6. MotoJohnno
    MotoJohnno Member
    May 3, 2006
    538
    The second one, easily.
    kryzak260
    kryzak260 Member
    Sep 30, 2002
    2,335
    London Gov'na
    Thanks guys.
    I actually meant to crop off that building on the left and forgot about it! I will see what I can do about the vignette also. I didnt put it in there in post, it's how to photo came out. It was still a reasonably dark scene at that point, and with the 10 stop ND on it metered for the sunset, the edges came out quite dark.
    Cheers,
    Michael
  8. beLarge
    beLarge Member
    Jan 2, 2012
    393
    The second is the pick
  9. broccoli
    broccoli Member
    Feb 21, 2010
    19,148
    I like the first one, don't like the second at all.
    kryzak260
    kryzak260 Member
    Sep 30, 2002
    2,335
    London Gov'na
  11. Zee
    Zee Member
    Oct 27, 2002
    10,009
    SYD/MNL/SIN/SFO
    I think that looks better.
    Z...
  12. ^catalyst
    ^catalyst Member
    11,821
    melbourne
    Yep, second one, second process. No brainer.
  13. a1ring23
    a1ring23 Member
    Nov 30, 2010
    240
    Agreed with above - much better.
  14. lothloriel
    lothloriel Member
    Dec 4, 2008
    3,235
    The latest update is quite nice. Very clean and simple.
  15. Mickatroid
    Mickatroid Member
    Jun 8, 2002
    1,570
    Can you pull out the lens distortion? The way all the masts tilt into the middle distracts me.
    FWIW I prefer the first shot with the nice sharp rigging and without the blurry clouds.
  16. jastormont
    jastormont Member
    Aug 10, 2004
    1,197
    I would go glass frame over the canvas as I think it will last longer and look better if done properly.
    Also like your reprocessed 2nd shot the best. :)
  17. juppy
    juppy Member
    Jun 3, 2002
    1,832
    Coffs Harbour, Australia
    Nice shots and I also prefer the second image without vignetting. However I would use caution when it comes to choosing the size of the image and framing. It may be best to go with a smaller image, well framed in a quality timber frame rather than a large canvas image. The reason being is that a large image can really dominate the room and might not suit their tastes or decor if its too large.
    I think wall art is a very personal thing and you always need to be cautious when purchasing/selecting for someone else. A smaller image allows them the freedom to put it on display on whatever wall they choose without fear of offending you if its not to their taste, a large image restricts them to large walls only which may force them to put it somewhere they dont really want it.
    In saying that, they will probably love the image and the thought that went into it, just keep in mind what I've said though.
    Also, a printed canvas will probably date a lot faster than a framed photo which is perhaps more timeless.
    kryzak260
    kryzak260 Member
    Sep 30, 2002
    2,335
    London Gov'na
    Thanks for the comments guys.
    I am going to go with the long exposure image de-vignetted as a 24x16" canvas, for reasons that juppy mentioned above. While i would probably print this at 40" wide or bigger because i have the perfect wall for it, i agree that it needs to be smaller to give flexibility in placement. Im going to go for canvas, because it fits the budget, where a good quality framed print would unfortunately tip it over.
    The friend is actually an amateur photographer also, so I think they will appreciate the image itself as much as or more than the physical print.
  19. juppy
    juppy Member
    Jun 3, 2002
    1,832
    Could you possibly get a nice "stock" frame and frame it up yourself rather than use a professional framing service? You might be able to find something that looks the part and matches the size image you want to print at without breaking the budget. Even if you have to get a custom mat board cut that may still save you a considerable amount.
