TeamGroup TForce 4000mhz
Discussion in 'Memory' started by Bolter01, Mar 10, 2020.
  1. Bolter01
    Bolter01 Member
    Oct 14, 2008
    600
    Ricktatership
    Testing out some TeamGroup TForce 4000mhzCL18,22,22,22 on ASUS Crosshair Formula VIII & Ryzen 9 3900X
    @ stock 4000mhz, manual tuning, fabric uncoupled, Samsung IC, stable
    yields slightly lower score on TimeSpy than coupled fabric 3600CL16 NEO, though these will also run @3600CL16 for equal results.
    Fairly dark as RGB goes, nice
    next is to see if the fabric clock can be pushed above 1800.
    Bolter01
    Bolter01 Member
    Oct 14, 2008
    600
    Ricktatership
    no problems pushing FLK beyond 1800 - 1833 -1867
  3. cbjaust
    cbjaust Member
    Sep 11, 2003
    1,279
    Can you improve tRCD and tRP at any given frequency? The 11ns latency at stock (for tRCD and tRP) is pretty slow, although my focus is on AM4 so I have not really looked into the high frequency bins. At the moment I'm benching a G.Skill kit at 1773MHz CL12.0 12-12-24-36 1T and for perspective CL12 latency at that frequency is 6.77ns. The stock timings of this kit seem slow but you show that tCL can show better latency.
    Bolter01 likes this.
    Bolter01
    Bolter01 Member
    Oct 14, 2008
    600
    Ricktatership
    yer exactly, I am sure the kit can tighten a great deal, but ATM I am still working out the GEAR DOWN mode, auto , enabled, disabled.. + other settings. So I have locked in many tRCD and tRP - from 18 -15 in Bio's yet boots at these due to 'some' setting which 'Gear downs' timings for optimum stability. Need to do some more research, the ram is certainly capable
    https://www.guru3d.com/articles-pages/team-group-t-force-xtreem-argb-ddr4-review,2.html
    incidentally if a Ryzen owner knows what Im talking about, please feel free to impart your knowledge o7
  5. DarkSnipa
    DarkSnipa Member
    May 13, 2017
    645
    I am surprised it is using Samsung chips, judging from timing Teamgroup is clearly planning to put CJR or DJR on this as well. :Paranoid:
  6. cbjaust
    cbjaust Member
    Sep 11, 2003
    1,279
    1T with gear down mode is like 1T but only sends commands every second cycle so It's better for stability than 1T gear down mode disabled, but faster than actual 2T command rate. With gear down mode enabled tCL can only be an even number as well.
    Bolter01
    Bolter01 Member
    Oct 14, 2008
    600
    Ricktatership
    cheers cbjaust, just for now I ran the Samsung B-die safe @ 16-16 no problems through Ryzen Master - seems to be the way to go ... I was old schooling in Bios and had had Gear Down disabled from the start. Will try tighter tomorrow :thumbup:
  8. cbjaust
    cbjaust Member
    Sep 11, 2003
    1,279
    Cool, cinebench is perhaps not the best benchmark to show improvements from faster and/or lower latency memory. Seems my F4-3200C14D-16GTZ will get through R15 at 1841MHz at CL14:
    Bolter01
    Bolter01 Member
    Oct 14, 2008
    600
    Ricktatership
    some serious low latency :thumbup: I will have a good look at this. Are you using Bios or Ryzen Master for timings?
  10. cbjaust
    cbjaust Member
    Sep 11, 2003
    1,279
    That one was Windows 7, so no Ryzen Master (never make the mistake of installing Ryzen Master on Windows 7) but I wouldn't use Ryzen Master for timings anyway. You have to reboot when changing timings in Ryzen Master, No? May as well just reboot and change everything in the BIOS.
    Right now I'm benching an Athlon 3000G and running CL12.0 12-12-24-36 1T.
    Bolter01
    Bolter01 Member
    Oct 14, 2008
    600
    Ricktatership
    so you are using an X370, the fabric clock is locked to mem speed? hence asynch? but you can push them down to 12CL wd!
    yes using Ryzen Master requires a reboot for timings adjustments, yet for some reason I am to discover, timings input in bios is not reflected on boot..? eg: in Bios ATM I have 14-15-15-15-30-50 So I will assume the gear down is active, though it is Disabled.
    All input is manual, no DOCP
    Master allowed to 16-16 timings which I could not do with bios. More research. Appreciate your input cb o7
  12. cbjaust
    cbjaust Member
    Sep 11, 2003
    1,279
    CPUz says async in the memory tab when running the integrated Vega 3 graphics.
    To test if gear down mode is actually disabled, set TCL to 15 and see if you get 15 or 16 in CPUz.
    3000G is Zen so fclk = uclk = mclk always.
    Bolter01
    Bolter01 Member
    Oct 14, 2008
    600
    Ricktatership
    amidst the turmoil, a had these Steel Viper 3733 arrive. A nice distraction and something to play with.
    I had been watch Buildzoids channel
    and these seemed like good value.
    So they easily, run FLK 1866 = mem 1866/3733mt even @ 16/19
    Bolter01
    Bolter01 Member
    Oct 14, 2008
    600
    Ricktatership
    a little tighter,
  15. cbjaust
    cbjaust Member
    Sep 11, 2003
    1,279
    Have you tried lowering tRCD and tRP?
  16. integralfx
    integralfx Member
    Mar 24, 2019
    29
    They likely won't go lower with CJR/DJR.
  17. cbjaust
    cbjaust Member
    Sep 11, 2003
    1,279
    I thought that Patriot kit was B-die
  18. integralfx
    integralfx Member
    Mar 24, 2019
    29
    3733 17-19-19 was B-die but now Patriot does 3733 17-21-21 while using the same part number.
    It also says SK Hynix in the DRAM manufacturer field in CPU-Z.
  19. cbjaust
    cbjaust Member
    Sep 11, 2003
    1,279
    Ah , yep. I didn't look that closely.
  20. Azzan
    Azzan Member
    May 31, 2009
    2,650
    I had 32GB(4x 8GB) TeamGroup TForce Xcalibur 4000 RAM(Samsung B-Die) on my previous Intel setup(9900KS + Gigabyte Z390 Aorus Elite & Asus Maximus XI Extreme), it was awesome RAM imo.
    https://imgur.com/t6x6Hym
    https://imgur.com/vFPZ8Lb
    Ran XMP no problem on both boards and was also able to overclock it to 4000 15-15-15-35 @ ~1.45v-1.50v without any problem, but didn't play around with it much so I didn't try other speed.
