Tele lens options for Sony
Discussion in 'Photography & Video' started by humanrace, Jan 19, 2020.
  1. humanrace
    humanrace Member
    Dec 12, 2009
    1,639
    I dont do much photography these days and also now dont keep up to date with gear so I'm really lost in choosing a tele lens for my Sony A7III.
    I currently have canon lenses with a MC-11 adapter and have been using 70-200 2.8 IS but have wanted something longer for some more abstract type landscapes.
    Looking at Tamron 150-600 G2 or Sigma 150-600 S. Any thoughts on these 2? I would have to adapt them and unsure how theyll do
    Also, anything else I should consider?
  2. thommo101
    thommo101 Member
    Jul 24, 2002
    1,046
    Perth WA
  3. TheBear21
    TheBear21 Member
    Aug 2, 2007
    2,511
    Central QLD
    I'd check them first. I am pretty sure I have heard the Tamron does not work adapted. Not sure on the Sigma. Best choice as mentioned is the Sony 200-600.
  4. lonewolf1983
    lonewolf1983 Member
    Jun 12, 2002
    4,571
    Perth, WA
    if i was to adapt it would be mc11 + the sigma 150-600
    the sport is a nice bit of glass but its heavy.
    as above the 200-600 would be the way to go if you have the $$'s
  5. Athiril
    Athiril Member
    Jun 11, 2003
    4,061
    Tsumagoi-Mura, Japan
    G2 is sharper at 600 than the Sigma iirc.
    but the best solution is the Sony 100-400 it’s 1.4x tc or the Sony 200-600
