Temp Monitoring
Discussion in 'Extreme and Water Cooling' started by thedirkdiggler, Apr 15, 2017.
  1. thedirkdiggler
    thedirkdiggler Member
    May 19, 2006
    346
    At the moment I have HWMonitor, that I open now and again.
    Is there a better program that can auto start, but edit so I only see some temps that minimize to the tray down the bottom right?
    Or even better, phone size lcd/usb that I can put on my desk showing temps?
  2. ginger_nuts
    ginger_nuts Member
    Sep 24, 2011
    1,222
    Morphett Vale, SA
    Are your temps that critical?
  3. Renza
    Renza Member
    Dec 1, 2004
    4,653
    Adelaide, 5051
    Aquaero :thumbup:
  4. Joe91
    Joe91 Member
    Nov 30, 2007
    1,323
    ACT
    Speed Fan - nil impact on CPU/memory, starts with Windows, runs quietly in the background and you can just hover your mouse over the icon to see temps.
    thedirkdiggler
    May 19, 2006
    346
    thanks for those 2. Will look when home from work today :thumbup:
  6. Plonkflopped
    Plonkflopped Member
    Feb 3, 2012
    229
    OpenHardwareMonitor. Simple looking and can have a gadget with all temps you want.
  7. fanpeople
    fanpeople Member
    Dec 30, 2014
    13
    4869
    AllezAllez likes this.
    thedirkdiggler
    May 19, 2006
    346
    cool.
    that is something like I am looking at :)
  9. ICEW0LF
    ICEW0LF Member
    Oct 17, 2007
    660
    sweet just ordered one
    thedirkdiggler
    May 19, 2006
    346
  11. TheWedgie
    TheWedgie Salty
    Jun 16, 2002
    2,798
    South Australia
    I have one of these, it's neat but the template system to design your screens can be a bit screwy to get it looking perfect. I've just stuck with pretty much the default for now, until I get some time to tweak it. I have no real need for network speed or pings, but getting the temperatures bigger was a pain (although I haven't spent too much time on it yet!).
    Their forums have a 'show off your screen' thread but nobody seems to share the actual template though :(
    Otherwise it's a great bit of kit. Be prepared to buy a better USB cable depending on your usage - right angled etc.
    Next on my todo list is to be able to display the temps from other PC's on the network (the HTPC can get a bit hot if someone leaves Plex on pause).
  12. fanpeople
    fanpeople Member
    Dec 30, 2014
    13
    4869
    Oh I know what you mean, first time playing around with it was an experience. I put it aside for a month and went back and put it aside for another month.
    I ended up actually learning how to use it when I had some time off work and after that it became pretty easy to tweak everything.
    It is a great blank slate, it is just one of those things that require a bit of effort to figure out what everything does.
    I am not the most computer literate, so I am sure a lot of people on this forum would have no issues whatsoever.
  13. heslo
    heslo Member
    Mar 16, 2002
    87
    Adelaide, Australia
    Had one of these for a few years, fantastic bit of kit!
  14. TheWedgie
    TheWedgie Salty
    Jun 16, 2002
    2,798
    South Australia
    Same, I gave up for a bit then went back and spent some time fiddling and got it a bit closer to how I want it to look. Just annoying there's a bunch of really neat screens on their forums but no one shares the template.
    What are you using to feed it values?
  15. fanpeople
    fanpeople Member
    Dec 30, 2014
    13
    4869
    I just use open hardwaremonitor DLL, just because I didn't like use all the other programs running in the background.
    I do wish people would share the templates, but then again if they did I probably would not have bothered to learn how to use it.
  16. thmrsh
    thmrsh Member
    Dec 5, 2008
    1,653
    goverlay looks great :)
  17. Rea:Per
    Rea:Per Member
    Mar 27, 2011
    235
    Sunshine Coast
    +1 for SpeedFan
    I use it together with Rainmeter for a temps, fan speeds, network & disk bandwidth usage.
    its great
  18. AllezAllez
    AllezAllez Member
    Mar 21, 2017
    62
    Aquaero..
    The Aquaero LT for independent control of pumps/fans/temp.
    Vision block for a desktop display. I was a bit cheeky and got the vision CPU block - a fun item but dubious in usefulness.
    The software is great too. The alarm function is great for peace of mind. If anything, Aquasuite is the killer app for its stability and detail. The integration of temperature sensors (inc. system temps) is just great.
