Tempered Glass Side Panels
Discussion in 'Modding' started by nammkit97, May 23, 2020.
  1. nammkit97
    nammkit97 Member
    Apr 20, 2013
    45
    Parkwood, 4214
    Hey guys,
    Does anyone know how they make the opaque black borders on tempered window side panels? Is it painted on? Thanks.
  2. havabeer
    havabeer Member
    Dec 12, 2010
    5,645
    you can paint it.
    you can get some aluminium strips, paint and glue them on.
  3. DSTM (Dougie)
    DSTM (Dougie) Member
    Jun 2, 2018
    652
    Western Sydney
    I would use black contact adhesive.Stick it on, and use a box cutter to trim outer edges.
  4. mtma
    mtma Member
    Aug 12, 2009
    5,342
    If it's plain black it's usually painted.
    If there is artwork in the border, then it might be a reverse mounted decal or film.
    nammkit97
    nammkit97 Member
    Apr 20, 2013
    45
    Parkwood, 4214
    Thanks for the suggestions guys. Really appreciate it. I might try painting first since that should be the easiest and cheapest route.
  6. havabeer
    havabeer Member
    Dec 12, 2010
    5,645
    alot of hobby shops will sell different effect paints as well.
    i would be going a matte black
    nammkit97
    nammkit97 Member
    Apr 20, 2013
    45
    Parkwood, 4214
    I was thinking the same. Got a can of matte black a couple of days ago. Planning on doing something like this. The window tint material appears to be PET according to the listing. Hopefully the paint sticks.
