Test Bench / Open Air BUILD, watercooled 295x2
Discussion in 'PC Build Logs' started by paulbaird87, Jun 2, 2015.
  1. paulbaird87
    paulbaird87 Member
    Sep 4, 2014
    61
    A little delayed since I am half way through but I'll bring you all up to speed.
    Aerocool Strike X Air (open air / test bench) case
    http://www.pccasegear.com/index.php?main_page=product_info&products_id=22318&cPath=547
    Asrock x99m Killer (soon to be Asus x99 Sabertooth) *bought a Rampage V Extreme
    Intel 5820k
    Corsair Dominator Platinum
    AMD R9 295X2 WITH EK nikel waterblock and backplate
    *added an extra 290x
    M.2 Samsung SM951(512gb)
    1x bootable backup 500gb hdd (weekly clones)
    2X 4tb hdd
    LEDs everywhere
    1000w EVGA P2
    480mm Hardware Labs Nemisis gts crossflow
    240mm XSPC rad
    Koolance D5 pmp-450 variovario
    Glass Skull Vodka bottle as Resovoir
    EK nickel plexi waterblock on gpu
    XSPC raystorm cpu block
    6X Aerocool Dead Silence 120mm red Led fans
    NZXT digital fan controller. Software based/on screen fan control and temp viewing.
    Early stages mock up of what the 480mm rad and Vodka skull res would look like on this case.
    More progress shots to come.
    paulbaird87
    paulbaird87 Member
    Sep 4, 2014
    61
    Progress
    Bought a few second hand sculls to practice drilling the glass, wasn't as difficult as I imagined, NOTE to others.... the faster the drill spins the easier it is and start on an angle to bed the drill bit into the glass without it jumping around.
    Dan Akroyd, Crystal Skull Vodka. (found a few on ebay empty for $5 otherwise would have cost me $100)
    should look like this with the blood red coolant
    First drill attempt had a few cracks
    Used some ultraclear araldite to seal the barbs to holes ( was tricky feeding the glue covered barbs through the lid and into the holes)
    Now to see how i can mount this, a 240 rad and a 480 rad on this alien space ship of a case.
    stay tuned.................
  3. zero_velocity
    zero_velocity Member
    Sep 16, 2010
    2,648
    QLD
    Looks cool man :thumbup: Ive always wanted to do a similar build for the giggles, they just look so cool :Pirate::leet:
    paulbaird87
    paulbaird87 Member
    Sep 4, 2014
    61
    progress
    Pulled out the beating beastly heart of my little matx build , this will go straight in the Strike X with the intention of upgrading to full ATX x99.... Any suggestions? best x99 mobo for overclocking????????
    Figuring out mounting options for this bad boy!
    The Aerocool Strike X has a little cross bar to mount things on but it is not very sturdy and in the wrong spot.
    paulbaird87
    paulbaird87 Member
    Sep 4, 2014
    61
    mounting comlpete
    Mounting the GTS 480 Crossflow was a nightmare and required some aluminium angle cut to size and bolted together at the back bottom right corner and the top left corner. I will redo this one day and use sexy black angle but the spray paint looks ok.
    Phase 1 complete. Still have the little EK dc pump/res combo and tubing from my old matx build.
    Phase 2 is a tidy up of the cable managment to accomodate more fans and lighting as well as new plumbing, pump, skull resovior and the EK nickel waterblock for the 295x2 that I have been dying to get since I got the card.
    paulbaird87
    paulbaird87 Member
    Sep 4, 2014
    61
    They do look cool. Initially I thought it might look too cheap and plasticy but with the system in it, the rad on the back and a few glowing fans it looks awesome.
  7. BigDave
    BigDave Member
    Nov 12, 2007
    3,705
    ADELAIDE/5018
    These things are an acquired taste mate, They have potential and yours is looking good :thumbup:
    paulbaird87
    paulbaird87 Member
    Sep 4, 2014
    61
    Looks a little tacky but easy to work with and just not the same as every other black/white tower with a little window.
    paulbaird87
    paulbaird87 Member
    Sep 4, 2014
    61
    Phase 2
    Phase 2 started on a sad note. My little AsRock X99M Killer died during initial benchmarks after water blocking and reinstalling the R9 295x2. Definitely wasn't a thermal issue since the gpu never got over 38 and the cpu not over 50 during tests. Only put 1.3v through the cpu and 1.35v on the ram and the motherboard temps seemed fine.
    Any way here is the 295x2 EK water block install process. I really took my time with this since it was my first gpu water block install and it paid off. It looks incredible and the temps are brilliant for the gpu overclocked.
    Step one, shroud and backplate come off.
    Then the asetek gpu pumps, front heat sink, rear gpu socket retainers and the double width pci retainer.
    Then onto removing the old thermal paste, thermal pads and cleaning the components for the EK supplied pads.
    Applying thermal pads and Phobya NanoGrease Extreme.
    Thermal pads for the back plate and back of the gpu
    So many thermal pads on this bad boy but it must be for a reason because after testing this on initial overclocks of 1130 core and 1625 memory neither gpu on the card got over 38 degrees on full load during all benchmarks running a 5820k at 4.4ghz and 2666mhz ram.
    Early benchmark results before my AsRock board died. Hoping to get this bad boy over 20000 for fire strike basic.
    Fire Strike = 19195
    Fire Strike Extreme = 9370
    Fire Strike Ultra = 5167
    paulbaird87
    paulbaird87 Member
    Sep 4, 2014
    61
  11. Ratzz
    Ratzz Member
    Mar 13, 2013
    9,201
    Cheltenham East 3192
    Also helps if you fill the bottle with well compacted sand before drilling. Will help prevent cracking.
    paulbaird87
    paulbaird87 Member
    Sep 4, 2014
    61
    Thanks for the advice. I filled it with water on the first cut and pressured it with a cork and it worked well.
    paulbaird87
    paulbaird87 Member
    Sep 4, 2014
    61
    paulbaird87
    paulbaird87 Member
    Sep 4, 2014
    61
    Rampage bios and initial results
    So i finally had time to get the ramage v in and do some benchmarks. I kept the same ram and gpu settings as the last benchmark on the AsRock micro but i did change the cache to 4.4ghz which i couldn't do on the AsRock. Thanks to the Rampage I managed to add few hundred points to my firestrike score and about 30 points to cinebench.
    Fire Strike = 19315
    paulbaird87
    paulbaird87 Member
    Sep 4, 2014
    61
    overclocking the open aired beast
    Got some more time to do a few more fire strike runs and stability testing the memory.
    This was the best fire strike 1.1 run
    Fire Strike 19643
    (4.5 core 1.4v 4.4 cache 1.35v vssca 1.2 3200 17,18,18,43,1t )
    Fire Strike Extreme 9908
    (4.4 core 1.4v 4.4 cache 1.4v vssca 1.15 3200 16,16,16,36,1t )
    Currently running at 4.2ghz core and cache adaptive and 3200mhz (16,16,16,38,1t) at 1.35v stable on 12 instances of HCI memtest to 400%
    paulbaird87
    paulbaird87 Member
    Sep 4, 2014
    61
    TRIFIRE, three way crossfire
    Bought a new 290x to run in TRIFIRE, three way crossfire.
    Initial benchmarks are pleasing, added a lazy 5 thousand to my firestrike score in both stock and overclocked setups.
    Overclocks where
    cpu; 4.5ghz core, 4.4ghz cache
    ram; 3200mhz at 16,16,16,38,1t
    gpu core; all three at 1100mhz
    gpu memory; all three at 1625mhz
    paulbaird87
    paulbaird87 Member
    Sep 4, 2014
    61
    paulbaird87
    paulbaird87 Member
    Sep 4, 2014
    61
    Extra 290x
    added the extra 290x, now running tri fire from two cards. Works well 4k BF4 at 60 frames zero drops
