The POWER CELL - ZenModz "COMPLETED"
Discussion in 'Modding Worklogs' started by Zenator, Sep 12, 2015.
  1. Zenator
    Zenator Member
    Jan 30, 2009
    464
    AUS
    Proudly Sponsored By.
    PC Build Specs:
    Height up to 700mm.
    Width: up to 400mm.
    Case Shape: cylinder. One base, One top, 3 Pillars, 3 clear windows. Being build ATM.
    Case Colour: Grayish/white, with some black & red.
    MoBo: Asus H97I-PLUS Mini ITX LGA1150 Motherboard That will mounted to the bottom and the case.
    GPU: ASUS TURBO GEFORCE GTX 960 OC Edition 2GB-GDDR5. Staying air cooled, This will be mounted to one of the 3 case pillars.
    Running on a PCIe cable. The TURBO GTX 960 with the exhaust out the bottom of the case,
    And the intake for the TURBO GTX 960 will come from the pillar it is mounted to.
    CPU: Still needed.
    RAM: Still needed.
    PSU: Still needed, Will be mounted in the base.
    Water Cooling, One custom 60mm x 400mm res. (2x 120 slim rads, CPU block, 1x Pump, fittings, still needed.) ( 6x90mm W 20x20mm H,D clear blocks running 9x5mm Round 500mm L tubing.
    that will be on the out side of the case as part of the loop. being built ATM)
    Lighting: Black Light, and some white LED's.
    Fluid: Neon Green, Still needed.
    Loop fittings: Still needed.
    Even though this is only my second Case Mod, I have been using ASUS Motherboards for many many years. I have always found them to be well priced and having lots of great features.
    And today is no exception. ASUS continue to add all the goods to there Motherboards and GPU's, Even for there low to mid range hardware you still feel you are getting more for less.
    As you will see below "Small" can still make a big impact and still play hard. And "Colour" is not Black or White its a shade of what your Imagination can do with it.
    Below are two of ASUS products that I will be using for this build from ASUS who I thank for helping me with my second case mod.
    The Asus H97I-PLUS Mini ITX LGA1150 Motherboard and the ASUS TURBO GEFORCE GTX 960 OC Edition
    This will be the first time using a board of this size. I find it hard to believe that something so small can still deliver so much. Just thinking of the doors for case modding this Motherboard has opened up for the different kinds of build that can now be done, that would have been imposable before. :)
    Unbeknown to me was this White TURBO GTX 960 OC Edition. The staff at ASUS could see what my new build was all about. And this White Knight is the perfect look for this build.
    I would love to go deep into the specs of this GPU. But I will leave that to the pro's at ASUS.
    here is where you will find all you need to know about the ASUS TURBO GTX 960 OC Edition.
    http://rog.asus.com/428182015/gaming-graphics-cards-2/unboxing-asus-gtx-960-turbo-special-edition/
  2. Kommandant33
    Kommandant33 Member
    Mar 6, 2011
    4,380
    Cheltenham VIC
    meh... I prefer Free cell.
    lelle jks... subbed :thumbup:
  3. Acesi7
    Acesi7 Member
    May 25, 2009
    2,148
    Curious to see where this goes.
    However, so far this is just an advert and I'm tempted to report it...:thumbdn: Please add some actual content.
    Zenator
    Zenator Member
    Jan 30, 2009
    464
    AUS
    Hi Acesi7 The pic's will be coming soon before the end of the week, Being a sponsored build it needs to be done right from the start.
    Thanks for stopping by.
  5. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,771
    Nulkaba
    Cant wait to see what your creative mind comes up with with this build:thumbup::)
    Zenator
    Zenator Member
    Jan 30, 2009
    464
    AUS
    Cheers, Mic :)
    Zenator
    Zenator Member
    Jan 30, 2009
    464
    AUS
    Project: POWER CELL is a go! :)
    Hi again every one, Going to be starting on some of the smaller parts first.
    To start off with im doing the out side water blocks/res there will be 6 in all three at the top and three at the bottom. All 6 will be part of the cooling loop.
    They will be fitted to the out side of the case, The three on top will be linked the one's on the bottom. So one top one will link to one bottom one, with 3x 5mm clear tubes and so on. on the back of each block will be one fitting that go's to a stand 1/2 mantel bent loop. back to one of the other blocks and keeps going. Lets just call the outer blocks (Loop rails.)
    So below I have started a quick step by step.
    for the blocks, after ill be adding the 3x 5mm tubes to the 2x blocks to make one (Loop Rail.) and this will be done 3 times.
    Will add more soon for the Loop rails. Still working hard on the Vector files for the case parts as well. And still working my full time job. Sleep! what is that I ask.:) But I have 10 days off after next week. For more Modding.
    Again as always thanks for stopping by.
    Cheers, Ken.
    Zenator
    Zenator Member
    Jan 30, 2009
    464
    AUS
    Hello again everyone. Ive put the 5mm tubing for the rails on hold for now as I well get a better idea of the length of them once the case starts going
    together.
    So what I have been going is working on the Motherboard armor and the back plate IO shield that will lock onto the Motherboard armor, Still need to make a hole for the CPU. but still not sure what CPU block will be used.
    Hope you can see where I'm going with what I have done so far.
    Thanks for stopping by. :)
  9. Wozzajeep
    Wozzajeep Member
    Feb 16, 2003
    352
    At The Track
    Keep going Ken!. Nice to see one of your builds from the start. I went through about 20 cups of tea just catching up with the progress on the Fallout build!.
    Zenator
    Zenator Member
    Jan 30, 2009
    464
    AUS
    Lol well done for starting from the beginning which must have been like reading a small novel, with photo's. Happy to know you are on top of it from the start this time. :) I lost count of the coffee's a long time ago! :Paranoid:
    Zenator
    Zenator Member
    Jan 30, 2009
    464
    AUS
    Hello Again, Still working on the case parts.
    Starting to get ready to order some of the parts that will be going into the case.
    Below is the Ai layout for the CNC.
    Lots more still to come. :)
    Thanks again for stopping by.
    Cheers, Ken.
    Zenator
    Zenator Member
    Jan 30, 2009
    464
    AUS
    Hello again.
    I have started working on the center res mount. So far I have made the casing, added some blue LED's, put some steel mesh around it. Still need to add a small electric motor to turn the black cover at the bottom. to create a rotation of light in side the case. Once that is done i will starting working on the rest of the res mount. And then add the rest of the trimmings.
    I would like to say thanks to forum member "primesuspect" for selling me the 400mm Res. it will be a Big help, Cheers.
    Thanks again for stopping by. :)
    Zenator
    Zenator Member
    Jan 30, 2009
    464
    AUS
    Hi All
    The CNC parts are now done, And are now being put together.
    Along with some of the hardware that will now be test fitted to the case.
    Then all the side pillars cut to size and will be added for the height, The Pillars will be box like to hide all the things you just don't want to be seen running from the top of the case to the bottom. MOBO tray has been made as well but still needs to be vented on the back.
    Hope you like it so far, Would love to know what you think. :)
    Will add some more pic Sunday.
    Thanks for stopping by :)
    Zenator
    Zenator Member
    Jan 30, 2009
    464
    AUS
    Hi Again
    One more update for today.
    Rad's & all 6 fans are fitted as well as the Res, It's now hanging from the top as well.
  15. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,771
    Nulkaba
    That looks com"plex" :):tongue:
    Zenator
    Zenator Member
    Jan 30, 2009
    464
    AUS
    No not that bad, :)
    Here are some progress pic's of the top cooling disk.
    Again thanks for stopping by.
    Cheers, Ken.
    Zenator
    Zenator Member
    Jan 30, 2009
    464
    AUS
    Hello again.
    Just a quick update of where I'm up to.
    The Power Cell is coming along nicely.
    I have been working on the base and the pillars one of the pillars will hold the GPU, The GPU will take air in from the outside of the pillar as well as the inside.
    Ive cut out and mounted the GPU and all is good. Still making the Pillars stronger by making them two layers thick in side the two layers will be a 20mm space to run wires and such to the top and back.
    MOBO and Pump are now in there places as well, Once all the hardware is fitted, and the case is complete all the hardware will be removed again so I can start painting the case. inside & out.
    Here it is so far. Yep its talllllllllll: And might I say Different. (H-700mm )
    As always thanks for stopping by. :)
  18. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,771
    Nulkaba
    is that all you've done, get back to work:tongue:;)
  19. Kommandant33
    Kommandant33 Member
    Mar 6, 2011
    4,380
    Cheltenham VIC
    Looking great, man :thumbup:
    Zenator
    Zenator Member
    Jan 30, 2009
    464
    AUS
    Thanks gents, I am still working on it as I'm typing....... :p
