thermal paste on i5 6500 and i7 6700k
Discussion in 'Intel x86 CPUs and chipsets' started by sjaeger172004, Aug 2, 2021.
  1. sjaeger172004
    sjaeger172004 Member
    Sep 15, 2007
    1,070
    Hi
    I am wondering what size thermal paste container I would need to redo a i5 6500 and i7 6700k
    Thank you
  2. radeon_freak
    radeon_freak Member
    Sep 19, 2007
    3,401
    You should be able to do both of them with a 1g tube using the grain of rice method. I get 2 mounts out of the small 1g tubes they ship with EK waterblocks but doesn't leave you any if you mess up or want to check the mounts etc. If you're doing the mounts yourself and you have shaky hands might be best to grab the next size up, 2g or 4g.
    sjaeger172004
    Sep 15, 2007
    1,070
    thank you
    sjaeger172004
    Sep 15, 2007
    1,070
    ended up getting
    Thermal Grizzly Kryonaut Extreme Thermal Grease 2g
  5. radeon_freak
    radeon_freak Member
    Sep 19, 2007
    3,401
    That's the good stuff but it's pretty expensive! Doesn't get much better tho :thumbup:
    sjaeger172004
    Sep 15, 2007
    1,070
  7. Matthew kane
    Matthew kane Member
    Jan 27, 2014
    3,147
    Theres moot point spending crazy money on thermal paste on the 6500 and 6700k because you won't see a difference till you delid, clean that shit gunk Intel uses, repaste with thin layer for smooth full coverage, then relid.
    Sneakypuss and Elmf like this.
