trimoniter problems
Discussion in 'Troubleshooting Help' started by Pipster, May 10, 2012.
  1. Pipster
    Pipster Member
    Sep 23, 2008
    584
    Hi everyone,
    Im currently running 3 Benq 2400W's off a 6970, using two dvi and one active display to dvi converter. Now the problem is whenever the computer goes to sleep, the active displayport converter is no longer detected, and the screen doesnt turn back on. Its a simple fix, all you have to do is go into screen resolution and redetect the screen, but its annoying. Was wondering if anyone knew how to fix this?
    Thanks
