Tripod Suggestions
Discussion in 'Photography & Video' started by roger1505, Feb 7, 2017.
  1. roger1505
    roger1505 Member
    Aug 18, 2013
    127
    Hey fellas,
    I've got the OMD Em5II.
    Just wondering whats the best compact and lightweight tripod for this camera?
    I'm planning to travel to NZ soon and desperately need a tripod that's above 1 meter high, but can collapse down to fit in a large backpack (Carry on Luggage).
    cheers
  2. davidblight
    davidblight Member
    Sep 9, 2012
    39
    I just travelled for 5 weeks with a Sirui T-025X - I hardly noticed it in my daypack, so much so that I've been carrying it around for the last week accidentally.
    It was more than sturdy enough for my A7Rii w/ 16-35mm too.
  3. isaakk
    isaakk Member
    Oct 10, 2014
    238
    NW TAS
    +1 for Sirui. I have a W-2204 and love the thing. Am looking to pick up a T-025X soon too so I have something lighter to carry around for travel/walking.
  4. Pbx_Jnr
    Pbx_Jnr Member
    Jun 12, 2003
    1,876
    Brisbane, QLD
    +1 for the Sirui T-025X :)
    I carried one around in my backpack for my India trip and it worked brilliantly for my 5D3. You can anchor it with your bag if you're worried about the sturdiness of it, but it really is an impressive bit of kit.
  5. 3Toed
    3Toed Member
    Oct 7, 2005
    135
    Sydney, Australia
    I bought a MeFoto RoadTrip last year for when I didn't want my huge Gitzo around. It can hold my D800 + 70-200 f/2.8 which is what mattered to me.
    It's not the lightest (~1.6 kg) nor most compact (~40 cm folded) tripod but I wanted the sturdiness. One of the legs can also be removed to convert it into a monopod.
  6. MickybD
    MickybD Member
    Jul 18, 2008
    591
    roger1505
    roger1505 Member
    Aug 18, 2013
    127
    Thanks for the responses.
    Wow really positive reviews on the Sirui. Also does anyone have suggestions on where I can get one? Staticice is showing the cheapest for $319.
    :leet:
  8. dodgyexposure
    dodgyexposure Member
    Aug 28, 2012
    148
  9. dan441
    dan441 Member
    Jul 14, 2008
    66
    If you're happy to risk ebay from china, $277 delivered
    http://www.ebay.com.au/itm/Mini-Tra...e-Professional-Sirui-T025X-C10X-/172080854168
    Or already in the country ebay, $298 delivered
    http://www.ebay.com.au/itm/SIRUI-T-...th-C10X-Ball-Head-for-DSLR-Came-/152240072659
    or roughly $319 delivered from B&H in America depending on exchange rate / conversion fees, etc :D
    https://www.bhphotovideo.com/c/product/1244072-REG/sirui_sut025x_t_025x_carbon_fiber_tripod.html
  10. macrocephalic
    macrocephalic Member
    Oct 17, 2003
    606
    -27.56, 152.93
    I bought a Q666c (comes branded as many different things) which is the Chinese rip-off of the mefoto. It was about $100 and seems pretty good so far. The screw legs are sturdy, but a little fiddly; the leg angle adjustments are a little strange - not the spring loaded type I was expecting. You can convert one leg into a monopole like the mefoto.
  11. RyoSaeba
    RyoSaeba Member
    Sep 11, 2001
    13,338
    I got a mefoto a few years ago too can't remember which model, but it's pretty small. Love it. Took it on my japan travel. Held up my DSLR fine.
    roger1505
    roger1505 Member
    Aug 18, 2013
    127
    roger1505
    roger1505 Member
    Aug 18, 2013
    127
    Just a quick review on the tripod after using it for a few months.
    I quite like the lightweight and compact design of the tripod, its able to collapse and pack into my backpack easily. Although being so lightweight it can be unstable under strong winds and/or inclined ground, luckily this problem can be solved with a carabiner provided with the tripod so a bag can be hooked to provide more weight.
    This tripod is definately travel friendly as it actually weighs less then my whole camera gear, so I'd reccomend it.
