try my thesis!
Discussion in 'Programming & Software Development' started by MadOnion87, May 14, 2009.
  1. MadOnion87
    MadOnion87 Member
    Jul 10, 2002
    3,232
    Old Trafford, Manchester
    Hi all,
    I want YOU to try my undergrad thesis! It's a Firefox extension that tries to predict where/what you want to go/do. At the moment it's only available in Linux (I might compile one for windoze over the weekend). What I want you to do is install it, then surf the net as usual for few days (so it can learn what you want to do) then try it out. Please vent all your frustration in the survey (link @ bottom of the website) so I can evaluate just how good (bad) it is.
    At the moment I would like to hear bug reports and other algorithmic suggestions. I'm not too keen on prettiness and configurability at the moment =)
    website:
    http://www.cse.unsw.edu.au/~swong/thesis/index.html
    thanks
    steve
  2. GumbyNoTalent
    GumbyNoTalent Member
    Jan 8, 2003
    10,185
    Briz Vegas
    Im sorry but that is so simple, just redirect to a porn site and you can predict 99% of the population... ;)
  3. alexlim2000
    alexlim2000 Member
    Nov 16, 2006
    108
    VERY GOOD PRODUCT
    WILL BUY AGAIN
    MadOnion87
    MadOnion87 Member
    Jul 10, 2002
    3,232
    sif awi lol
  5. Foliage
    Foliage Member
    Jan 22, 2002
    32,083
    Sleepwithyourdadelaide
    Compile it for windows and I will give it a shot.
  6. xsive
    xsive Member
    4,343
    So what does it do, exactly? And how does it work?
    Please be technical.
    EDIT:
    OK, so looking at your thesis draft it seems you use a Bayesian classifier to suggest where a user might want to browse to next. This is based on past browsing information that extracts page titles and associated keywords. Once the classifier is trained (I presume this is where the week-long "do not use until" requirement comes from) you analyse the current page and recommend links. You should have said so up front.
    It sounds interesting. Do you have a minimum threshold probability before you make a recommendation or are links always recommended? Also, I don't understand why you're planning to use a survey to evaluate your algorithm. Surely it would be better to use logs from individual user's machines? At least then you could compare how close the link that was eventually clicked on was to the recommended link.
    EDIT2:
    I notice your thesis intro is pretty vague (I had to read quite a bit to find out what you were doing). Why include "History of Computing"? As I see it, the only bit in Chapter 1 relevant to your thesis is *the last paragraph*! :eek:
    MadOnion87
    MadOnion87 Member
    Jul 10, 2002
    3,232
    Foliage: I will probably compile a windoze version over the weekend
    xsive: That's because I haven't quite plan out what I'm gonna do when I wrote my thesis A report (which is almost a year ago). And I realised that my thesis topic itself is too general. You can disregard most of what I've wrote for thesis A. So there are two things I look at. 1) changes in URL. 2) the relationship between the [title + keywords in meta tag] and [the link you just clicked]. I've made an assumption that the title and stuff between <a href..> </a> tell you something about their respective webpage. Might sound like simply counting numbers at first, but if you want to calculate proper probabilities, its ridiculously difficult.
    [edit] I've also updated the version to include a few bug fix [/edit]
    MadOnion87
    MadOnion87 Member
    Jul 10, 2002
    3,232
    I've compiled a windoze version.
    I'm not gonna try and guarantee its stability lol. If it crashes/too slow/got too frustrating, just remove it.
    thanks
    [edit] hmmm seems to have lots of trouble recognising it, firefox doesn't seem to refresh the extension list [edit]
  9. eyeLikeCarrots
    eyeLikeCarrots Member
    Jan 1, 2002
    4,389
    Canberra Is Shit Sex: Yes
    If you stay with this assumption, make sure you doccument it in your paper.
    No need to re-direct to a porn site... 90% of the population will go there themself anyway.
    "The Internet as a research tool.... lol"
