tv sound bars
Discussion in 'Audio Visual' started by anark1, Apr 26, 2020.
  1. anark1
    anark1 Member
    Aug 13, 2004
    1,764
    melbourne
    recently purchased a new TV and the wife suggested a sound bar as she is not yet cool on fitting the lounge out with 5.1
    are these units worth getting? maybe with a sub.
    or are they pretty bad unless you start paying a fair bit of cash on them?
  2. Holdenkicks
    Holdenkicks Member
    Mar 30, 2003
    913
    Central Coast
    The second one. They’re average unless you spend at least $1200+.
    a Yamaha rxv385 with $400 bookshelf speakers will be just as good as a $1200 soundbar set up and gives you a platform to expand to 5.1 when you’re ready.
  3. elvis
    elvis Old school old fool
    42,819
  4. phreeky82
    phreeky82 Member
    Dec 10, 2002
    9,581
    Townsville
    Physical volume of speakers (box volume and baffle size included) plays a pretty big role in the ability to deliver quality sound. They're also throwing in amps, sound processing, input switching etc into relatively cheap devices.
    If you want the best quality, don't look for something cheap and with lots of channels. A 2.1 or 3.1 unit will most likely be your best bet.
    If you definitely want a proper setup down the track and holding off due to convincing the wife, I suggest looking at receiver+bookshelves+sub, perhaps buying bookshelves that will eventually become your surround speakers.
    anark1 likes this.
  5. power
    64,945
    if you want to try out a half decent one without spending a lot, cash converters have shit tonnes of these things (at least the one I went to did).
    My parents wanted something for their tele and I grabbed an older Sony soundbar cheeeeeap.
    I was actually surprised myself how good it was, being an older bar it cost a fraction of what you pay for a new one.
    It was fairly deep and their tele could have sat on it, had a great remote and all the other things you need.
    Only caution i would make is older ones are unlikely to be HDMI 2.1 I guess.
    anark1 likes this.
  6. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    155,717
    Omicron Persei 8
    I think they meet the criteria in terms of space saving with often better quality than TV speakers. But really that's not saying much. I run a $150 sound bar (with sub) because the sound on the TV in the study is crap, it's a Soniq TV. The soundbar makes the sound pretty decent in the room and I'm quite happy with it.
    If you're looking for a bigger room and want a really quality sound you're going to need a bar worth at least 1K..... and the rest. I like the compactness of the bar + sub without having to set up speakers around the room.
  7. Zee
    Zee Member
    Oct 27, 2002
    11,583
    SYD/MNL/SIN/SFO
    Sonos Arc about to be released - is an all in one 5.0.2 Atmos solution (probably). $1400 rrp, though.
    Z...
  8. Soc
    Soc Member
    Jun 26, 2001
    929
    I've got a Sonos playbar. We added Sonos ones as rear speakers and a playsub too.
    All bought second hand, saved a motzah.
    I really like them.
