twitch streaming - zooming x 2 or ? for a webcam for scenery
Discussion in 'Overclocking & Hardware' started by super kermit, Aug 21, 2019.
  1. super kermit
    super kermit Member
    Jun 18, 2002
    1,219
    Sydney Lane Cove 2066
    I want to set up a cam streaming 24/7, but need to zoom in on an area and doing it digitally is horrible for quality.
    Logitech c922
    This is normal view and the area I want to zoom into are in red
    [​IMG] [​IMG]
  2. Copie
    Copie Member
    Jul 24, 2009
    13,806
    Newcastle
    Dont bother with a shithouse webcam, use something decent like a unifi G3.
  3. CAPT-Irrelevant
    CAPT-Irrelevant Member
    Sep 7, 2007
    6,970
    I have the C920, which is the predecessor. Web cams are meant to be short range scope only. You'll want a wifi-enabled digital camera to do what you want.
    super kermit
    super kermit Member
    Jun 18, 2002
    1,219
  5. power
    61,964
    super kermit
    super kermit Member
    Jun 18, 2002
    1,219
    Should I use ELGATO hd60PRO OR AN ELGATO CAMLINK?
    I have read USB is too limiting.
  7. mesaoz
    mesaoz Member
    Jan 15, 2015
    5,567
    Straya
    twitch's max bitrate is 6,000 - usb can easily handle that.
  8. power
    61,964
    super kermit
    super kermit Member
    Jun 18, 2002
    1,219
    So my idea of using a normal camera has not worked out.
    Is there a PC camera I can use that has a zoom that will plug in via USB or wifi that will let me zoom in?
    And is around $150?
    super kermit
    super kermit Member
    Jun 18, 2002
    1,219
  11. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,713
    ADL/SA The Monopoly State
    you can try a smart phone telescope lens on your web cam but it's probably gonna be just as shit, don't forget webcams aren't actually 1080p, they're way lower res upscaled internally.
    an old canon powershot with custom firmware maybe, but running a digial camera 24/7 will almost certainly wreck it as they're not designed to run the sensor that long.
    just run a second camera outside.
  12. havabeer
    havabeer Member
    Dec 12, 2010
    5,473
    I still don't get what this is for?
