UPDATED: Cluster half finished
Discussion in 'Business & Enterprise Computing' started by Newton, May 5, 2006.
  1. Newton
    Newton Member
    Jan 24, 2003
    59
    Wollongong
    Project: "Cluster PC"
    6 x Pent III 1ghz c/w HD's, 3 PSU, 1 10/100 switch.
    PSU's , switch etc will be housed in black box, everthing will be painted matt black... cold cathode in box... etc etc...
    ps. cables have not been tidied up, hard drives yet to be installed, perspex coating yet to be stripped off. Mobo power up switches still to be mounted .. still a couple of thing to fix to make it look sleek.
    Hosted by UGBox Image Store
    Any suggestion or Comments would be appreciated ...
  2. coroner
    coroner Member
    Aug 7, 2001
    331
    looking awesome mate
    What Operating system are you going to put on it?
    keep us posted with your progress looking very interesting :thumbup: :thumbup:
    Newton
    Newton Member
    Jan 24, 2003
    59
    Wollongong
    Thanks, REDHAT, openmosix... already tested system works great... now gota get it running in the format you see it...
    Will post final pics when uint is cleaned up...
    Any suggestions as to a final color, maybe a gloss RED
  4. stmok
    stmok Member
    Jul 24, 2001
    8,878
    Interesting...
    I was planning to build one myself...Using dual PIII mobos. (I had like 6 or 7 of them)...But I lacked the necessary economic resources to complete (I was broke at the time), so the project was abandoned...Now I have a bunch of dual CPU mobos used in various PCs for other roles. :lol:
  5. coroner
    coroner Member
    Aug 7, 2001
    331
    i would keep the black going, or try to make it look like a cupboard or something against your existing furnitute.
    What cluster specific tasks have you got for it currently?
    Newton
    Newton Member
    Jan 24, 2003
    59
    Wollongong
    Movie rendering...
  7. stmok
    stmok Member
    Jul 24, 2001
    8,878
    Looks pretty cool, now that I can see how you've got the PSUs rigged up. ;)
  8. gonutz
    gonutz Member
    May 6, 2002
    391
    cant wait to see your powerbill :)
  9. HeXa
    HeXa Member
    Jul 7, 2001
    10,216
    Canberra, ACT
    shouldn't be too bad.... P3s aren't very power hungry... unlike P4s
    - HeXa
  10. coroner
    coroner Member
    Aug 7, 2001
    331
    depending on OS system size requirements, maybe you could install onto usb thumbsticks to save space etc if its needed
    Newton
    Newton Member
    Jan 24, 2003
    59
    Wollongong
    Using a selection of 10gb and 20gb drives, the project is how to recycle old comp parts, thumb drives would not fit the theme...
  12. chewbucca
    chewbucca Member
    Jun 4, 2003
    1,891
    London
    how loud is this monster? :shock:
  13. music_pirate
    music_pirate Member
    Nov 25, 2004
    254
    I'd love something like htat! except i would make it slimmer/longer so I could fit it under my bed :lol:
    Also, the noise would help me sleep more (i sleep better with noise for some reason :p )
    Goodluck with it mate ;)
    Newton
    Newton Member
    Jan 24, 2003
    59
    Wollongong
    slimmer and longer ??? hmmm ... that's a 15" monitor it's next to, I could make it about half height, but it would be hard to carry and move ...
  15. GOATMAN!!!
    GOATMAN!!! Member
    Apr 10, 2005
    677
    Iowa, USA
    Aren't you worried about those PSU's killing themselves in their own heat?
    Newton
    Newton Member
    Jan 24, 2003
    59
    Wollongong
    4 x 90mm fans in the bottom of case and another 16 40mm breather holes in bottom... NO box should be well ventilated... :thumbup:
  17. GOATMAN!!!
    GOATMAN!!! Member
    Apr 10, 2005
    677
    Iowa, USA
    Ahh fair enough then :)
  18. unix
    unix Member
    Jun 30, 2001
    1,890
    Perth WA
    Just out of curiosity, if you run a cluster with 2 x P4 Dual Core 2.8Ghz, instead of the 6 which you are currently running now, which will give you better performance?
  19. infiltraitor
    infiltraitor Member
    Sep 7, 2002
    3,801
    melbourne Donated:$133.70
    so 4x 2.8 or 6x 1.0, which is better? is that your question?
    id say the 4x 2.8 would be better..
    the 6x 1.0 MIGHT be better if you want to do 6 things at once rather than 4 but it would take longer to do those 6 than it would to do 4 on the 4x 2.8 (if it was a time based task).
    he may be doing 6 endless tasks and then the 6x 1.0 would be better than 4x 2.8
  20. pete_pumpkin
    pete_pumpkin Member
    Nov 29, 2002
    666
    25km north of Adelaide
    Wow, interesting project. How does the OS share the work load?
