Upgrading PS3 hard drive
Discussion in 'Sony Consoles' started by Akh-Horus, Jul 29, 2011.
  1. martykins
    martykins Member
    Mar 14, 2007
    529
    Collie, WA
    You need a USB hard drive which has equal to or greater size than the hard drive currently in your system. This drive needs to be formatted as FAT32 and then before replacing your hard drive run the backup tool on the PS3 which will copy all data to the backup hard drive.
    Once you have installed the new hard drive its just a matter of restoring the backup using the utilities on the PS3
  2. ni9ht_5ta1k3r
    ni9ht_5ta1k3r Member
    Feb 11, 2006
    34,649
    地球・オーストラリア・シドニー
    pretty much....
    1. format new HDD to FAT32
    2. connect new HDD to PS3 via USB
    3. run the back up process in the PS3
    4. connect and dump back up files from new HDD to PC
    5. wipe new HDD
    6. take out HDD from PS3 and replace with the new HDD
    7. run the setup process to format your new HDD now in the PS3
    8. take the old HDD and reformat to FAT32
    9. dump the back up files onto old HDD
    10. connect the old HDD via USB
    11. run in the restore function in the PS3
    DONE!
  3. Everlong
    Everlong Member
    Jul 12, 2011
    771
    Hysperia
  4. Bertross
    Bertross Member
    Feb 2, 2009
    13,486
    Melb, CBD, East Subs
    chucked a spare 250GB in on the weekend, took 20 mins from downloading the UPDATE from PSN to installing it and applying the update, Hi 5. Wanted a 750GB but beggars can't be choosers.
  5. RoBB22
    RoBB22 Member
    Jul 16, 2008
    182
  6. The Beast
    The Beast Member
    3,552
    Back down under!
  7. Everlong
    Everlong Member
    Jul 12, 2011
    771
    Hysperia
    Good to know thanks. I have read that the 7200rpm drives give a bit better play tv performance, can anyone confirm/deny this? Cheers
  8. 2SHY
    2SHY Member
    Aug 10, 2010
    7,707
    Sydney NSW Australia
    Much of a Muchness. Just install it.
  9. The Beast
    The Beast Member
    3,552
    Back down under!
    I have a 500Gb 7200rpm Scorpio Blue in mine (can't remember the cache size, 16mb maybe) and Play TV is very smooth.
    I installed a 750Gb in another PS3 though, and the write speeds were terrible - I think there must have been some kind of sata controller compatibility issue. The PS3 is Sata1, and some HDDs have jumpers that can limit them to sata1 which you might want to use if you're installing it in the PS3. Just a thought.
    As a test, install a game that has a mandatory HDD install before you replace your HDD, then try it again with the new one to make sure it's no slower. The 750Gb I installed was noticeably slower for some reason (didn't affect gameplay though) and installing or copying anything to the HDD was painfully slow.
  10. RoBB22
    RoBB22 Member
    Jul 16, 2008
    182
    well i finally bought a new hdd, backed up onto a external, formatted new hdd, then re launched the backup, all was going good, acept i have a few games that i purchased that will not work, it wants me to purchase them again
    should i goto transaction history and re download?
  11. mrthong
    mrthong Member
    Sep 21, 2009
    1,578
    Geelong, 3215.
    yes. the games are locked to your psn/sen, not your harddrive. odd, did you sign into psn and then try loading the game?
  12. droopz
    droopz Member
    Oct 28, 2005
    839
    Katherine - NT
    As a long time high end PC gamer, the load times on my new PS 3 really piss me off. Is there a real-world performance gain in throwing in a SSD?
    Given I only have he console for a single game I don't need much space so a small one will be fine.
  13. Pieface
    Pieface Member
    Dec 12, 2009
    410
    I used an ssd for a while with gt5. Definitely improved loading times. They weren't instantaneous by any means but it was highly noticeable when I went back to using a regular hdd.
    At an estimate I'd say 30-50% faster?
  14. droopz
    droopz Member
    Oct 28, 2005
    839
    Katherine - NT
    Good enough for me. I'll grab one from work tomorrow. :)
  15. RoBB22
    RoBB22 Member
    Jul 16, 2008
    182
    yeah i was signed into my account
  16. vespas
    vespas Member
    Oct 4, 2006
    302
    can the seagate and toshiba 2.5" external hdd be used in the ps3 if you remove the cover? i want to upgrade.
  17. ni9ht_5ta1k3r
    Feb 11, 2006
    34,649
    地球・オーストラリア・シドニー
    you still need to extend the sata and power connectors.
  18. vespas
    vespas Member
    Oct 4, 2006
    302
    are they too big for the caddy
  19. Nightwish
    Nightwish Member
    Apr 14, 2008
    1,913
    sorry if this has been asked previously but i'm wondering if putting a new HDD in a PS3 would void the warranty? I was reading somewhere that you need to tell the console to use the new HDD as a primary disc which means the PS3 won't use the old one unless you format it again
    Is that true?
  20. HyRax1
    HyRax1 ¡Viva la Resolutión!
    7,911
    At a desk
    No it won't. It's a user-serviceable item.
    All you need to do is download the latest firmware from Sony's website, put it on a USB stick to reload the OS files onto the new HDD when you first turn it back on with the new drive.
