Urgent help Macbook Bootcamp
Discussion in 'Apple Desktop Hardware/Software' started by supaflygy, Nov 20, 2007.
  1. supaflygy
    supaflygy Member
    Jul 14, 2007
    383
    ARRGGGGH
    i am trying to install bootcamp XP
    went through the bootcamp assistant went for the resart and now i am stuck with
    Press aqny key to boot from CD
    Disk Error
    Press any key to restart.
    Guess what, i cant find the ANY key and none of the others work either:wired:
    restart just brings the same result. FFS
  2. chrisorm
    chrisorm Member
    Feb 14, 2002
    856
  3. almghty
    almghty Member
    1,172
    You needed to format the partition.
    Bootcamp assistant formats it to FAT32 but somehow its not really ready, it just looks ready.
    So when you started the windows install I'm guessing you didn't format the partition? Format it again during the windows installation to say FAT32 (which is what I did so i could copy files off it) and it should work.
    Same thing happened to me..
    Cheers
  4. holodeck3
    holodeck3 Member
    Jun 26, 2001
    468
    Inner Western Sydney
    agreed with almghty - I had the same problem and was getting really peed off with my machine. Turned out that if you format it, all works fine.
    Once you select the partition in the windows installer, tell it to format it for FAT32 (if you want R/W access to it) or in my case, NTFS (I only use it for my amateur radio study so dont need to write, just read).
    It only adds about 10 seconds to the process if you choose quick. I chose full, but it was only a 5 gig partition, so took only a few mins.
