USB 3.0 Front Panel / CASE / CONFUSION?
Discussion in 'Newbie Lounge' started by shredR, Sep 13, 2011.
  1. shredR
    shredR Member
    Nov 10, 2007
    665
    OK so I'm building a new rig (Purchased 2500K, ASRock Extreme4 M/B, Sapphire HD6950 2GB) so far.. Now the M/B has 2 x Front USB 3.0 ports & 2 x Rear USB 3.0 ports.
    Now, does this mean I will need to purchase a case that has USB3.0 ports in the front in order for this to work?? I'm currently looking at the 600T which has (1) USB 3.0 front input, however I would like to cut down the cost to under $200 for a case and purchase an NZXT (most likely) which has NO USB 3.0 front header.
    My ASRock came with a "1 x Front USB 3.0 Panel" which has 2 slots. Does this mean I can just hook this up to my M/B and place it in one of the 3.5" spaces on my case?
    Is this a dumb question? I feel like I know a lot about computers, but seeing as I havent purchased any hardware for a while, I'm a tad confused at this.
    I don't see the point in buying a USB 3.0 m/b if I can't use any front ports.
    Cheers in advance! :thumbup:
  2. Ethan W
    Ethan W Member
    Jan 13, 2011
    1,693
    NSW, 2155
    Sorry for glancing over your post, but keep in mind that a LOT of cases claim to have front USB3 ports which are just "passthrough" cables to the back ports. if you have proper USB3 headers on the motherboard (socket with individual pins), then look up the reviews to make sure the case you're looking at has proper USB3 headers. I don't think the 600T does, because the 650D doesn't.
  3. MiseryIsMajesty
    MiseryIsMajesty Member
    Aug 9, 2011
    77
    Melbourne, Victoria
    Reading your post.. Your mobo comes with a USB3.0 bracket that I assume fits into a 5.25" drive bay. This means you do not have to purchase a case with native USB3.0 support. However, if you don't wish to use this bracket for whatever reason (ie. Aesthetics), there are many cases with front panel USB3.0.
    I have a 600T and it's just a pass-through cable. However, I didn't like that much, so I bought a BitFenix Internal USB3.0 Adaptor, as my Sabertooth P67 has the header on it.. Works great.
    Just some food for thought. :)
    shredR
    shredR Member
    Nov 10, 2007
    665
    So when you say the 600T has a pass-through cable, what essentially does that mean? So if i was to use the USB 3.0 port on my front panel (on a 600T) I would need to purchase the BitFenix connector? That enables the port to be "USB 3.0".. My apologies if im totally off the ball!
  5. Fishface
    Fishface Member
    Mar 17, 2004
    1,613
    The pass through cables are terminated with USB 3 plugs and pass through the case and out through the back panel to plug into the rear USB 3 sockets.
    The bitfenix thingy converts them into a header to plug into the MB inside the case.
  6. joshpond
    joshpond Member
    Aug 3, 2011
    592
    Townsville
    I have the same motherboard and the HAF X case which has USB 3 front ports.
    You options basically are:
    Included with the mobo, the cable plugs into the mobo 19 pin internal connector and there is a 3.5in drive bay adabter which gives you two usb 3 ports. If you have a case that doesn't have usb 3 posrts at the front, as long as you have the drive bay you can get usb3 with no extra cost.
    If you case has usb 3 front panal it depends on how they connect up.
    Some like the pass through and on mine are basically a USB 3 extension lead. These are designed to pass out the back of the case and plug on the mobo's backpanel usb 3 port. (which are like mine)
    The ASRock drive bay adapter however can be pulled apart so that it basically has 2 female usb3 ports. I've run this cable behind the motherboard tray and plugged the fron usb 3 pass through cables from the case into the female end of the mobo cable.
    hope that makes sense.
    Josh
  7. Marksman X
    Marksman X Member
    Jun 5, 2010
    1,831
    Victoria
    Fractal Arc Mid Tower has a front USB3 header that plugs directly into the ASRock Extreme4 motherboard. I have both of them :thumbup:
    Link.
    Case is bigger than it looks, and really, really well built.
    shredR
    shredR Member
    Nov 10, 2007
    665
    I think I'm just going to go with the 600T... I'm very picky and I can't find another case that I like for the price range.. There are some full towers that I like but I just don't need a case "that" big... I guess as long as I have the option of using USB 3.0 (which I will via the back I/O panel on my m/b) and 1 port at the front, that should be more than enough! Unless someone can suggest why a 600T isn't a good purchase?
  9. MiseryIsMajesty
    Aug 9, 2011
    77
    Melbourne, Victoria
    In regard to your original reply to my post, the pass-through cable is just a USB-to-USB cable running from the front panel, designed to be routed out the back of your case and plugged into the USB3.0 ports on your mobo.
    To be honest, the 600T is borderline "full-tower". It's a little wider and taller than your average mid-tower. Apart from that, it's a great case, love the build quality and design. Has a pretty generous window too, with the option of installing mesh for extra side-panel fans in place of it, which is included.
    Indeed one of the better-looking cases out there, in my opinion.
